duckhunter27
- duckhunter27
Ok guys , I'm having a problem with the 6061 breaking in the haz . I'm using 5356 .047 wire . 100%argon . I'm running around 130 to 160 Amps on a xmt 350 . Everything has been cleaned with acetone and stainless steel wire brush . I've also tried to use a helium argon mix and even did inter pass temps of letting it cool to below 150 before the next pass . Any help or suggestions would be greatly appreciated as always fellas .
- image.jpeg (46.05 KiB) Viewed 914 times
- image.jpeg (59.74 KiB) Viewed 914 times
- image.jpeg (44.32 KiB) Viewed 914 times
- image.jpeg (60.32 KiB) Viewed 914 times
Can't directly help, but perhaps two bits of info about brakage on HAZ that may be helpful:
http://www.thefabricator.com/article/al ... 6-or-4043r
http://www.esabna.com/us/en/education/b ... -alloy.cfm
Bye, Arno.
Bye, Arno.
Are you pre- or post-heating this weld?
6061 will have a very abrupt hardness change near the edge of the weld if it's not annealed to some extent across the HAZ.
Pre-heating to 275-300F will help broaden the HAZ on the 6061 side so the hardness change is not so abrupt. I generally don't post heat, but I'm usually welding large enough sections that air-cooling takes a while.
Just some thoughts...
duckhunter27
- duckhunter27
We tried pre and post heating to no avail . I did figure out the problem they were having . The bender they were using to test the test lives was not correctly setup .
Too tight a bend for the thickness? That'll do it. 6061 has radius limits other alloys don't suffer from.duckhunter27 wrote:We tried pre and post heating to no avail . I did figure out the problem they were having . The bender they were using to test the test lives was not correctly setup .
duckhunter27
- duckhunter27
Exactly what is was . To small of a bend radius by 3/8ths . They called me in to figure out why they failed the test. When I walked in the aluminum was sitting on rusty work table , grinder with a regular wire wheel , and a couple grinding wheels . No stainless brushes and no acetone to clean with .
