    Wed Nov 19, 2014 8:20 pm
    S.W. Pennsylvania
Since I am new to TIG welding and have become pretty damn good at regrinding tungsten's due to frequent dipping :roll:
There have been a few times when I have to totally remove the collet to get the tungsten back in the torch. I noticed the o-ring that seals the back cap is getting beat up. Sometimes it is up on the threads when I remove the cap. Is there a hi temperature lube of some kind I can put on the o-ring to help keep it in the groove? Any tricks you guys have?
And what kind of o-rings are these that stand up to the temperatures in the torch. I want to order some to have replacements.
Brian
Miller Thunderbolt 225 AC/DC
Everlast 255EXT with W300 cooler
Hobo Freight 170 MIG Welder
melsdad wrote: There have been a few times when I have to totally remove the collet to get the tungsten back in the torch. I noticed the o-ring that seals the back cap is getting beat up. Sometimes it is up on the threads when I remove the cap. Is there a hi temperature lube of some kind I can put on the o-ring to help keep it in the groove? Any tricks you guys have?
Not sure why this would happen, anyway the o-ring should be available as a replacement part from your supplier.
Viton o-rings are good up to 400°F
100 % silicone o ring lube from Grainger is what I use on o rings that may see chemical or high temp service. Made by jet lube. Down side is its 75$ a tube. And it will collect lots of grinding dust and nastyness in a place where you don't want it!
    Thu Dec 25, 2014 9:25 am
    near Chicago
Silicone Plumbers Grease. Cheap at Lowes. Your regular O-rings should hold up to heat just fine unless your melting your torch and then you have more to worry about than o-rings :lol:
    S.W. Pennsylvania
The first place I went was CK's website to get a part number for the o-ring. Unless I am missing something I don't see the information. There are exploded views of the torch with the o-rings visible, but no particular call out of the part.
So how hot does a 250 amp water cooled torch get? I'm guessing 400° is plenty.
Brian
dunkster
    Sun Jun 28, 2015 7:41 pm
    Florida
melsdad wrote:So how hot does a 250 amp water cooled torch get? I'm guessing 400° is plenty.
That end of the torch, I'd be surprised if it saw half that.
Different story on the business end.
Have you asked your LWS? It seems odd that your having trouble with this o-ring. Screwing the backcap on and off shouldn't be an issue that would damage this. Call CK and ask them for a part number, it seems the o-ring comes with the backcap
dirtmidget33
    Tue May 13, 2014 5:22 pm
Usaweld.com (HTP) has them on hand if you call them not on there website. There was a discussion awhile back ago on orings that might help you.
http://forum.weldingtipsandtricks.com/v ... f=5&t=7383
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Brian I'm pretty sure I have a pack of them, of you PM me your address I'll drop them in the mail. I'm in York County, PA..
    Sat Mar 08, 2014 10:39 pm
    Holley, FL
melsdad wrote: The first place I went was CK's website to get a part number for the o-ring. Unless I am missing something I don't see the information. There are exploded views of the torch with the o-rings visible, but no particular call out of the part.
The CK Worldwide Part# 200R is for the o-ring that fits the back cap of the CK20 and other 2 series torches.
The part number can be found in the upper-left of page 3 of the CK20 TIG Torch Manual.
200L, 200M, and 200S are the CK Worldwide part numbers for the long, medium, and short back cap assemblies.
