Just got my Miller bobcat 250 mounted to my truck and started laying down a few practice beads. Haven't touched a welder since high school 12 years ago. Machine was set to DCEP, I'm guessing 110-120ish amps, still trying to get used to the settings on the machine. 1/8" 7018 on some 1/4" plate. Rod angle varied between 0-20 degrees, I'm just trying to get a feel for what does what. any comments are welcome!
- image.jpeg (67.72 KiB) Viewed 1372 times
plain ol Bill
- plain ol Bill
Don't whip 7018 - it will lay smooth as butter if you don't.
Tired old welder
CNC plasma cutter
Colorful shop w/
CNC plasma cutter
Colorful shop w/
Welcome to the forum!
I agree, I wouldn't whip 7018 in the flat position. Try higher amperage if for nothing else to see the difference. I would drag that rod as smoothly as you can and practice away. It's looking good though.
Treat it like a good woman. Lower, slower and make little circles!
I prefer tight circles to dragging. It keeps my old ass from falling asleep under the hood!
I prefer 125 to 135 amps and keep a tight arc. When the slag just rolls off by itself,
you're in the pocket!
No intentional whipping was going on, was getting dark and I was getting a lot of glare in my hood so I was having trouble keeping a straight line. Picked up a leather chin flap to help with the glare.
When you guys talk about keeping the arc tight and dragging, should I literally be dragging the rod on the workpiece? I'll crank the amps up a little and work on keeping a steady smooth feed. I've read 6-8" of weld per rod is pretty average?
I drag slightly pretty often - edge of the flux lightly touching the plate.
I also like 125-135 amps as well.
I use a little side to side, or other small motion since I'm going to move and sway a bit anyway - so I just go with it.
That position on th dial should be about 65-70 amps that may be a bit low for an 1/8 in rod. Try a 3/32 rod at that setting. I don't usually bump up in rod size to 1/8 unless I'm doing 1/2 in or thicker material. But most of my stuff is position welds so I trade the speed of the 1/8 for a little control.
Some fine adjustment dials are 0-10 instead of 0-100, his may be one of the 0-10.Poland308 wrote:That position on th dial should be about 65-70 amps that may be a bit low for an 1/8 in rod. Try a 3/32 rod at that setting. I don't usually bump up in rod size to 1/8 unless I'm doing 1/2 in or thicker material. But most of my stuff is position welds so I trade the speed of the 1/8 for a little control.
Yup, 0-10, so 60-130 and 10 should be the full 130, correct? I'm still trying to get used to the settings. On this machine if I'm set to 60-130 and 7 that should be about 110 amps right? I'm figuring this based on 70% of the 70 amps between 60-130. Is that right?MinnesotaDave wrote:Some fine adjustment dials are 0-10 instead of 0-100, his may be one of the 0-10.Poland308 wrote:That position on th dial should be about 65-70 amps that may be a bit low for an 1/8 in rod. Try a 3/32 rod at that setting. I don't usually bump up in rod size to 1/8 unless I'm doing 1/2 in or thicker material. But most of my stuff is position welds so I trade the speed of the 1/8 for a little control.
Dirt_man wrote:Yup, 0-10, so 60-130 and 10 should be the full 130, correct? I'm still trying to get used to the settings. On this machine if I'm set to 60-130 and 7 that should be about 110 amps right? I'm figuring this based on 70% of the 70 amps between 60-130. Is that right?MinnesotaDave wrote:Some fine adjustment dials are 0-10 instead of 0-100, his may be one of the 0-10.Poland308 wrote:That position on th dial should be about 65-70 amps that may be a bit low for an 1/8 in rod. Try a 3/32 rod at that setting. I don't usually bump up in rod size to 1/8 unless I'm doing 1/2 in or thicker material. But most of my stuff is position welds so I trade the speed of the 1/8 for a little control.
That sounds about right.
Just adjust the machine till the puddle is right.
Numbers don't mean anything.
0-10 0-100. As long as he knows how the dial system works that's the important thing. Seen lots of guys who don't know and then don't ask until a box of grinding wheels later.
Little more, one side is 7018, 6011 on the other. Bumped it up to 130 amps. Getting slightly better, still has a pretty tall crown to it.
Above the file tang is the 6011, first time using that rod, tried a few different rod manipulation Styles.
- image.jpeg (73.75 KiB) Viewed 830 times
