![Image](http://i169.photobucket.com/albums/u235/musico79/welding/1205152029_zps91cqgwog.jpg)
![Image](http://i169.photobucket.com/albums/u235/musico79/welding/1205152136_zpsyhskxz7b.jpg)
The straw and blue colors are due to the Ti not being shielded until it's cooled to 800F or less, if its gray or very dark blue then this is worse. If you're welding to a code or customer spec then they should say what is acceptable, usually a straw color would be accepted.big gear head wrote:I have to weld some titanium at work from time to time. I usually have some color around the welds. I was wondering if that is bad and what problems it could cause.
Yea it's very easy to weld, the gas shielding is the big difference. I had some production Ti parts to weld that were thick enough I could weld these outside of an argon chamber, the thickness of the part drew the heat away quick enough that the gas lens provided all the shielding needed.big gear head wrote:The parts that I weld are used in acid. That is why they are made of titanium. I just get some straw and medium to light blue. Titanium does make some pretty welds and it flows very easily.
That right there is what sucks about tig welding thin titanium tubing, in a sense. No where near enough metal mass surrounding the weld head that you have to have some kind of heat sinking if you wanna get anywhere in a reasonable amount of time.LtBadd wrote:big gear head wrote: I had some production Ti parts to weld that were thick enough I could weld these outside of an argon chamber, the thickness of the part drew the heat away quick enough that the gas lens provided all the shielding needed.
