Dirtynails
    Sun Oct 26, 2014 1:49 pm
Anyone use 1% Thoriated (yellow) 3/32 tungstens? How does the 1% compare to the 2%?
Dirtynails wrote:Anyone use 1% Thoriated (yellow) 3/32 tungstens? How does the 1% compare to the 2%?
Does your supplier offer the 1%? Personally I've never seen the 1%
Dirtynails
It's some old stock made by Osram/Sylvania.
88MOOSE88
    Fri Jul 11, 2014 11:13 am
    Grimsby, united kingdom
2% carries the heat better, I've founded with 2% if you accidentally dip the tip goes all furry and the heat isn't directed as much.
with aluminium is not much use, the ball dances around and doesn't seem to stabilize.
Dirtynails
Screen shot 2015-09-19 at 3.52.25 PM.png (216.12 KiB) Viewed 697 times
Dirtynails
Any thoughts as to how much current a 3/32 yellow will handle regularly?
Dirtynails
Screen shot 2015-09-19 at 4.24.58 PM.png (53.61 KiB) Viewed 689 times
CanMoulder
    Wed Apr 22, 2015 1:02 pm
    Ontario Canada
For the welding i do at work i use mostly 1% (yellow) and don't really find a difference between 1% and 2%
work just got the E3 ( purple) and the guys seems to like it
I need to finish out the 10-15 i have on the go befor i try something else
Sorry no help here
Kev
