For practice I have been welding 2 inch .035 6061 round tubing with ninety degree miter butt welds. I have had surprisingly good luck but was wondering if there were a preferred method to weld the outside corner portion of the joint. Also I noticed very little info on this type of weld when I googled it. How is it structurally? Thanks
jwright650
- jwright650
My guess...if welded correctly, IMHO, the outside corner would be the strongest part of the joint as it would be mostlikely a full penetration weld if it melted all the way to the inside....regardless it is a groove weld vs a fillet weld if I'm picturing your joint correctly.
John Wright
- Miter Joint.jpg (3.75 KiB) Viewed 1066 times
Thanks for your input. The attached image is what I was talking about. On my welds the bead protrudes on the outside corner and that is why I was wondering if there were a particular method for this weld. In this image the outside weld looks flush with the outside edges of the tubing, much better looking than mine.
Structural strength on that joint depends on where the load is coming from. With Alum you always will use a little filler, with that thin full penetration is easily achieved.
jwright650
- jwright650
Nice welded joint in that pic. After I posted, I thought about it more and I see what you mean...but like stated already with that thickness it should not be a problem.doneinone wrote:Miter Joint.jpg
John Wright
