delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
I have a job where I have to cut out several hundred of the same shapes. The job won't pay enough to justify buying a computer controlled plasma torch and the pieces need to be plasma cut because of the heat outline the torch will make ( it's an art thing). What I would normally do in this situation is cut a shape template out of hardboard (Masonite or MDF), clamp it to the steel and follow the template along with the torch. It works good, but each piece of hardboard is only good for a few cuts until it chars up from the heat and then I need a new template. I'll go broke on time and hardboard cutting new templates for every two pieces of steel....
So.... what would be a good material to use for templates? It needs to be at least 3/8ths of an inch thick, non conductive to electricity, able to take an intense amount of heat, and be easily cut with a bandsaw.
Thanks!
Other Steve
Negativ3
    Fri Aug 22, 2014 5:25 am
    Southern Thailand
Shooting from the hip here... never tried.
Could some thick glass, water-jetted to the required shape for plasma cutting work?
It maybe possible to stack multiple layers (Epoxy) to get the required thickness if 3/8" not available and you would need to provide an exact template of what you want or a cad file for them to cut.
A thin pad of rubber could be used to allow a clamp to secure while cutting and you would need clean surfaces to prevent breaking.
Not very bandsaw friendly but just a thought. :)
Andy
Roast beef and Yorkshire pudding is my personal signature dish.
Stupid questions are better than stupid mistakes.
I use highly conductive jigs for plasma all the time. No insulation, and no issues. I'll drag the tip directly against a stainless fence.
If your machine refuses to cooperate, you could make a metal jig with non-conductive, replaceable stand-off feet.
    Tue Jan 07, 2014 9:06 pm
    Elizabeth, WV
I slip on the tig finger and go at it free hand. :lol: I would use a piece of wood, I use wood all the time for stuff, never had trouble with burning.
Matt
    Sat Jul 06, 2013 11:16 am
Couldn't you use the stuff that a Tig torch insulator is made of? I think it's call Derlin, it comes in sheets of all thicknesses.
    Sun Oct 27, 2013 10:57 pm
Otto Nobedder wrote:I use highly conductive jigs for plasma all the time. No insulation, and no issues. I'll drag the tip directly against a stainless fence.
I was also wondering about the non-conductive part since I drag along a piece of angle iron often.
But that's only on low, my high setting wouldn't allow that because it requires a stand-off. (Older Miller spectrum 700)
The use of a non-conductive layer, or feet, would work excellent for my machine on high. Thanks for the idea :)
    Mon May 12, 2014 12:06 am
    Downey, CA
You could use Teflon PTFE sheet plastic,
From McMaster-Carr:
"PTFE has a slippery surface and surpasses most plastics when it comes to chemical resistance and performance in extreme temperatures. It resists most solvents. This material is also an excellent electrical insulator and can be used outdoors."
Color: White, unless noted
Temperature Range: -350° to 500° F
Tensile Strength: Poor
Impact Strength: Good
Glen
Negativ3
    Southern Thailand
A pantograph?
J1NGaZZkTn8
    Sat Apr 26, 2014 8:42 am
    Houston, TX
Best idea yet!
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
I like the pantograph idea!! Very nice.
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Negativ3, Top Suggestion! Thanks
    Tue Aug 19, 2014 2:34 am
    Short Creek, Arizona
That pantograph is awesome!
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
great tool very ingenious
Jason_alex
    Fri Jan 24, 2014 1:41 pm
If you need a lot cut you could also look at outsourcing to a company that has a CNC plasma table. But the pantograph is a great idea.
delraydella
    Detroit, MI
The pantograph is very cool! Great idea!!
