Just looking for a chop saw. Easier for me to make mitre cuts on tubing. Only be used as for a hobby. So the cheapest good quality is best. So what do y'all recommend
Sent from my DROID RAZR HD using Tapatalk
As a hobbyist, you can get away with an inexpensive abrasive chop saw. If you don't mind spending a few more $$, step up to a dry cut saw. Your accuracy, speed, and cleanliness will improve dramatically. I started with a Ridgid abrasive saw and am now running an MK Morse 14" dry cut. Needless to say, my abrasive saw is gathering dust on the shelf. ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
For hobby use, DeWalt at Home Depot is a good compromise between accuracy and cost.
Horrible Freight has one that actually has a better table, but the motor is not too durable for hard use. It may well be fine for hobby use, at a much better price. A hint on HF saws... Run it for 10 minutes without cutting anything, to seat the brushes, and it'll last longer.
A 14" chop-saw has much longer blade life. a 10" chop-saw will be more accurate (less blade flex)
Just some options to weigh.
- Wiredwelder
![Image](http://img.tapatalk.com/d/14/05/17/8u3ytuhe.jpg)
![Image](http://img.tapatalk.com/d/14/05/17/ha2eru7y.jpg)
It Cuts like butter just have to take your time and be careful! For accuracy I give it a 10 with a new blade. After about 12-20 cuts it starts to degrade. Get around 30 cuts per blade.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
- Wiredwelder
That saw takes 7.25 circular saw blades that are cheap.... 10$ cheap. And the saw has a no hassle 3 year return warranty. I'm on my second one. As aluminum has a tendency to break the fences on chop saws when it kicks!
- Wiredwelder
![Image](http://img.tapatalk.com/d/14/05/17/u4a6ubaz.jpg)
That is a cool light. Start a thread on that one.
