I have been welding stuff for a while but the more I read, the more I realise I still have to learn a lot.
I plan on making something like this:
![Image](http://img257.imageshack.us/img257/6136/01situacininicial.jpg)
![Image](http://img69.imageshack.us/img69/6660/02mecanizadosuelo.jpg)
![Image](http://img153.imageshack.us/img153/9549/03cajninoxde25mm14kg.jpg)
![Image](http://img109.imageshack.us/img109/7703/04instalacioncajonherme.jpg)
![Image](http://img580.imageshack.us/img580/6655/05situacionfinal.jpg)
I is basically a stainless steel sheetmetal box. The one posted here is 2,5mm thick and weights like 14kg. I was thinking about making it a tad thinner, say 2mm, to save some weight.
The thing is that I only have an inverter stick welding machine. Actually a Solter Cott S machine. I bet that for sheetmetal a MIG welder is the way to go but I have to make do with what I have now.
I only grab stainless rods (don't ask me which ones are right now because I have no idea, I need to check it out) when I weld stainless nuts on small pieces of stainless angle iron. So that's my unexistent experience with stainless steel rods. All I know about stainless rods is that slag pops off by itsell when you expect it the less so safety googles under the welding hood are a must.
My questions are as following:
- Is it possible to weld 2mm stainless sheet metal with my stick welding machine?
- Which kind of stainless should I try to get?
- What kind or rods and in which thickness? I guess the smaller the better... so I can run them at low amps and not blow too many wholes (some will happen no matter what).
- How should I approach this welds? Should I try to weld the inside corners or I am better off welding the outside ones? Maybe both just to make sure it doesn't fall appart?
- Stringers? weaves?
- Do theese rods fool you like 6013 do sticking only to both pieces of metal but leaving a slag filled crack in the middle or do they actually fill in the gap?
I will probably buy a whole 1000x2000mm sheet and have it cut to size so I don't screw it up cutting it with the small angle grinder. I guess I could save some welding having a few bends made. Big U shape and welding only the side plates if you know what I mean.
Well, I am open to suggestions!
Thanks in advance,
Mikel
