Hey guys,
I have a deco project. Not functional, no fears.
Is there a Chem to remove the rainbow? My project is thin and narrow so not much sugaring on the farside, so this is secondary.
I am sure there are some serious treatments out there. (In an industrial setting)
This is for outside in a container, or inside, if it's citric or something that won't get the wife's knickers in a pinch.
Thanks!
pickling/passivation acid. i highly recommend getting the neutraliser as well.
it won't get sugaring off, need a grinder for that.
i use the sandvik pickling gel paste but there is tons of brands out there.
To remove the coloring, simply brush the weld with a clean stainless brush. This works very well especially while the weld is still hot.
Since the material is very thin and sugaring is present on the opposite side, personally I would not worry about passivation because that oxidation will be the source of rust if that piece lives outdoors.
i have doubts about the sugaring causing rust on the other side of the material. even if you grind it off it will still rust.
with just wire brushing, it will eventually rust. nothing major but it looks bad.
one of the reasons for pickling/passivation is to remove the iron from the surface so it can't rust.
Dufus.
I should have mentioned... 316 fusion, no filler.
it makes no difference.
if you want stainless welds to not rust or to be clean then pickling acid is the way to go for home gamer.
yes its nasty stuff, so i do mine in the garage or outside. hence use the neutralizer to make it safer so i can move it to the hose and wash it off.
i find the neutralizer also helps clean what the acid doesn't.
Thanks a lot. I'll look for that juice.
How'd you know it was SS?
not to sure what you mean.
i assume you had stainless as its the only common metal that gets rainbow colours and sugar on the backside.
if you where welding some exotic metal you would not be asking such questions.
drizzit1aa
- drizzit1aa
12v power supply and dump as much salt in a cup of water it can absorb. Make an applicator, (wooden spoon with a sponge on it), swipe the sponge on the area that needs to have the coloring taken off. Start low on volts and work your way up until it works. Caution too much for too long and it will etch any stainless. The name I put in this sword is around an 1/8" or more deep.
- 26962125_1986599894701725_2177354844815387335_o.jpg (121.77 KiB) Viewed 2254 times
