h7m1
    Wed Jul 25, 2018 11:34 pm
Up for sale is a CBS C-1700 AirStream Micro Fibre Cable Blowing Machine Cable Installation kit in excellent conditio, ready for use immediately.
It is in superb ready to use condition with no issues at all with this kit, it has been well handled and maintained absolutely well.
Specifications of the machine:
Cable Diameter: 2.5 to 11mm
Tube Size (Outside Dia): 5 to 18mm
Cable Speed (Adjustable): (0-80m/min) (0-260 ft/min)
Air Pressure: 10-15 Bar (145-215 psi)
Power Requirement: 110/220 Volt AC
Width: 300mm (11.8”)
Length: 460mm (18”)
Height: 270mm (10.6”)
Net Weight: 14kg (31 lbs.)
This machine comes complete with the following:
1 x NEW CBS C-1700 AirStream Micro Fibre Cable Blowing Machine Cable Installation
1 x Power Supply
1 x Protective Case
1 x Air Compressor Attachment
1 x PVC Cutter
1 x Tool Kit.
The main features is as follows:
Automatic Cable centralising
Synchronous high grip profiled compliant drive belts
Tabletop design with ergonomic controls for ease of operation
Forward and reverse
Variable torque and speed controls
Digital servo motor drive system
Single person operation
Digital cable speed and length monitoring
Auto stop facility when air stone fitted
Integral air valve and pressure gauge
Easy cable threading
Polycarbonate safety guarding
Lightweight and compact
Low maintenance
Low noise levels
Travel case
Tool Kit.
AirStream
The C-1700 Air Stream has been designed to maximise protection for micro cables with a compliant double drive concept, backed by the latest technology in servo controls to provide precise control of torque and speed. Single person operation with safe, easy to operate ergonomic controls combines with low maintenance and high reliability to form the machine’s key features. The Air Stream is adjustable to suit a wide range of cable diameters 2.5-11mm.
It comes complete with everything intact, no faults at all with this kit.
Asking Price: USD$11,500.00
If you are interested kindly send me a message via Mail to esales2 at protonmail dot com
Thanks for looking....!!!!
h7m1
Price reduced to USD$11,300 for a quick sale
h7m1
A reasonable offer is welcome
h7m1
Going for $11,000 shipped
