Hey all. I have a weird issue I can't find an answer to. I'm using a Vulcan Migmax 215 running off 240 on my generator. Pictures below are using a 1/8 piece of angle iron that I prepped before welding. .035 wire on synergic settings. When running straight beads in a flat horizontal position, I'm not getting full slag coverage. As soon as I have any amount of vertical such as a t-join I'm getting a normal slag profile which is easy to remove and the weld doesn't have the oxidation. I have changed every variable I could think of from brand new wire spool, new tip, drag angles, contact tip length (recommended is 3/4"), wire feed speed, voltage, travel speed etc... and it always happens with flat welds. I can confirm polarity is also correct. Any ideas or tips as I practice?
What polarity are you running for FCAW? How much stick-out do you try to have? What torch angle? Try running a bead within the center of the piece, not along the edge. If you didn't fully clean the edge and backside, then you can pull contaminants into your weld area.
sorry to say, the Vulcan is not a very high end machine so don't expect real miracles. And Flux Core while a good process on higher end machines, is not conducive to great looking welds on entry level boxes. The Vulcan is not a true "synergic" box, for the record.
I have to disagree, while the synergic settings on the migmax 215 are not often correct, it is a fine machine if you understand how to set the machine manually. I am also not sure I would care what the slag looks like if the underlying weld looks acceptable. In my experience slag issues are from not running hot enough. Welding in the vertical dimension always puts more heat into the metal for the same settings. But you don't provide enough info to make any decent recommendations. Are you dragging or pushing the puddle? (if it has slag you must drag as the old adage goes) what is your polarity set at? (for most flux core wires this machine will use, you need to be electrode negative, meaning the negative output is connected to the MIG gun and the positive electrode connected to the work clamp...based on the amount of spatter, I am guessing you have the incorrect polarity), and what do the flat welds look like when the slag is removed? Also make sure you are not running gas by mistake.
Polarity is correct. See below pic. I am using a drag angle of about 10°. There is no gas running as I don't even own a tank to plug in the back. CTWD is 3/4". Weld underneath is solid. I'm not saying it looks good due to my skill, but it is solid metal at least.
I know the welder isn't a name brand $2000 welder but countless reviews and work I have from other career welders I talked to beforehand say it is perfectly adequate. I am not expecting any miracles, you're right. I just want to confirm if I'm addressing what needs to be addressed and it's just the nature of the wire in that position, or if I really do suck that bad
Edit: forgot to mention I get the same results anywhere on a piece of flat metal. I went to the scrap yard on my lunch today and grabbed some 1/4" steel and other pieces of scrap to keep experimenting on to see if I get any different results with various thicknesses.
one very important thing is what wire are you running?
there is some big differences in wire. quite likely its not the one the machine is programmed for, which is usually why "synergic settings" don't work.
tweake wrote:one very important thing is what wire are you running?
So far it happens with Vulcan wire and also Lincoln Innershield NP-211
np-211 is really for thinner material.
my guess here is lack of heat which is why it ran better uphill.
crank it up a bit.
while these wires might be the same spec, they all behave a bit different. synergic settings will get you in the ball park but you need to adjust from there.
I agree, as long as you don't go too crazy with the gun angle, and you are running sufficient amperage the keep the puddle nice and fluid, the slag will still tend to collect towards the rear of the puddle so long as you keep proper travel speed.
I think, yes, it's somewhat typical; you don't always get 100% perfect slag coverage with FCAW-S wires. It could be a symptom of too much arc voltage and/or improper stickout. The arc exerts a pressure on the molten weld pool and the slag as well (which is what make a bead flatten out). Try running only the minimum voltage needed to obtain the proper fusion at the toes of the weld. But of course the stickout needs to be correct in the first place.
It might also be a limitation of the wire diameter as it can only hold so much flux powder. 045 diameter wire might fare better in that respect. I'll try it out tomorrow with mine.
Oscar wrote:It might also be a limitation of the wire diameter as it can only hold so much flux powder. 045 diameter wire might fare better in that respect. I'll try it out tomorrow with mine.
Thanks! If you could try it and maybe post a photo that would be awesome. The reason why I’m so obsessed about it is after watching the Lincoln FCAW troubleshooting video where the guy is able to get good slag coverage with 035 NR-211-MP wire.
030 no-name gasless flux core wire I bought on Ebay or Amazon about 5 or 6 years ago. complete slag coverage in the flat position. Even ran two test beads. Both came out fine. So it might be either your settings or your technique, maybe even the wire. But if I can do it with this crappy no name wire that is years old, I'd surely think you can too with Lincoln wire.
If you have the time and inclination, I can work with you to try and figure out what you or your machine is doing wrong, assuming the wire is not compromised.
Hey all, brand-new welder here. Not really qualified to be handing out advice, but since I had this same problem recently and think I have it figured out, I thought I'd chime in. I've only been able to find this question asked two places in all of the internet, with no definitive answer, so hopefully this helps someone in the future. I'd also appreciate input anyone might have regarding the root (pun totally intended) cause of the observed behavior.
In my case, my first-ever stringer beads had plenty of problems, but slag coverage wasn't one of them. That changed, however, in the next couple days of practice. As everything else about my beads got better, the slag coverage issues got worse. I experimented with every parameter I could, to no avail. Then I realized that the one thing different between my first-ever beads and my nose-to-the-grindstone practice is that I set up a fan blowing across the work to keep me from breathing in the fumes! So I turned off the fan, and whatdayaknow... no more slag coverage problems. Now, without a fan, I notice that the only times there's a break in my slag is in spots where the wind temporarily kicks up, and can predict where the breaks will occur based on that. I'm guessing maybe the reason the op & others are having this problem only in flat position is that in vertical, the work itself is shielding the weld from the wind?
I guess (this is the part where I'd love to hear what y'all think), the cause is either (or both): The wind physically blowing off the compounds that would otherwise cool & solidify over the surface of the weld, or the weld cooling too quick to allow the same compounds to bubble up to the surface. Does either make sense?
