- Chips O'Toole
Can someone recommend a good water-cooled TIG torch? I have an AlphaTIG (200 amps) with a 17-series torch.
- crashbandit
BillE.Dee
- BillE.Dee
hi chips....IF you do an internet search for water cooled torches you will find many. You will have to make the decision as to your wallet and desires. I have a couple 20 series water cooled torches (can't tell you what brand they are without looking) which I find comfortable for my broken hands and fingers. You will have to make sure that the torch that you do decide on will connect to your machine. I don't know if ahp has their own brand or use a popular brand. You could give them a call and ask what they might recommend or do your own search. ck (worldwide??) has some. BUT I will tell you this ... when you get and use it,,,make certain the cooler is working and pumping water . I never turn my cooler off, even if i'm using a gas cooled torch. If you're looking for recommendations, I can imagine you will get a few different answers. Also, make sure that you will have the accessories for the water cooled torch. My 20's use the same parts as my 9. I might have an 18 and "think" it uses the parts of a 17 and 26. I hope I didn't confuse you with my typing. Let us know how you make out.
Bill
Bill
You ask about the torch, but didn’t ask about a cooler. What cooler are you planning to use?
I’ll second CK for torches and consumables
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
I've never had the chance to try the Weldtek Speedway torch, but I did see them at Fabtech last year and they do look nice.
Oscar, do they use the standard torch consumables that you'd use on a CK torch?
I have used CK for many years, one thing to look at is the duty cycle, CK is 100% on AC and DC for their water cooled torches. Well at least the 20 series that I use, I can't say I've check the spec for every torch.
Even the "standard" versions of the WeldTec/TecTorches are nice. Their WT-20H looks very much like a WeldCraft WP-20 but it has a bigger conductor and takes the full 310A of AC that my Sync250 will put out.
I've heard that WeldTec/TecTorch was started by a guy who left WeldCraft and then improved upon WeldCraft's designs.
- Chips O'Toole
I have been out of town, but I saw the responses, and I will make use of them. Thanks.
