What’s this called? It is an adapter from my syncrowave 250 which connects the foot pedal to the pulser (miller pc-300) and the pulser to the syncrowave. If it’s not too expensive I’d like to buy a new one. If not I’ll have to resolder it since most of the connections broke
Thanks!
Junior Welder
- Junior Welder
- 8D731720-4016-4E56-B3D5-FC53DD382A1A.jpeg (30.23 KiB) Viewed 830 times
I'm a 9th grade student teaching myself how to weld.
ESAB Migmaster 250 (MIG)
Miller Two Fifty Twin (Stick)
Junior Welder
- Junior Welder
Other connection:
- 6A14A8C0-44D0-4CC0-B96E-665B4D1B8E9C.jpeg (34.69 KiB) Viewed 819 times
Mike Westbrook
- Mike Westbrook
You can get those connectors on Amazon but they come from China only takes about 6 months to ship.... the 14 pins are very common the other dinse may match up to some aircraft ones
Junior Welder
- Junior Welder
Thanks for the replies! Looks like I'll have to resolder. I found one at arc zone either for $50 or $150 but can't remember now. Too much either way.
No not both ends are male. I have two of those things, one from pedal to pulser and the other from pulser to welder, and I just happened to get both male ends for the pictures.
Thanks again
Thanks again
That makes more sense. It's probably both those part numbers then.
Check out mouser or digikey if you want to make some new ones as spares. The plugs/sockets are only $5 or so and something like 10 cents for the pins.
"Your welds should sound like bacon. If your welds smell like bacon, you're on fire." - Uncle Bumblefuck (AvE)
