Junior Welder
    Wed May 30, 2018 5:15 pm
    BC Canada
Hello all,
I have been mig welding approximately once a week/once in two weeks for almost a year now.
I have been welding almost each day for a week or two. Tonight I welded this scrap metal tee joint.
Can you give me some advice on what I could do better? Does correct machine adjustment make for les spatter?
Here are some pictures:
I'm a 9th grade student teaching myself how to weld.
ESAB Migmaster 250 (MIG)
Miller Two Fifty Twin (Stick)
Junior Welder
    BC Canada
More pictures
Junior Welder
    BC Canada
More pictures
Junior Welder
    BC Canada
More pictures
    Sun Nov 19, 2017 10:09 am
Are you using Flux-core wire?
Everlast 210 EXT
CJ737
tungstendipper wrote:Are you using Flux-core wire?
If he is, he needs to reverse the cables and run DCEN to help eliminate the spatter.
Beads look good, travel speed is good, consistent tie-ins, heat looks right. Spatter is killing you.
theaceofgates
    Fri Mar 23, 2018 10:07 am
    Rio Rancho, NM
try adjusting wire speed just a bit. It might help.
TheAceofGates.com
FB_TheAceofGates
...professional tip clogging, rod sticking tungsten dipper.
Junior Welder
    BC Canada
No.
I’m running 0.035 ER70S-6 solid wire with c25 gas
Junior Welder
    BC Canada
theaceofgates wrote:try adjusting wire speed just a bit. It might help.
Up or down?
Up or down?
Yes.
And make certain your CWD is tight enough. Spatter can be symptomatic if long arcing it.
Junior Welder
    BC Canada
What do you mean by CWD?
Junior Welder wrote:What do you mean by CWD?
Contact to Work Distance, HERE is a short write by Lincoln Electric
Warrenh
    Thu Apr 27, 2017 12:31 pm
Are you pushing or pulling and what settings are you using. Also, what gas? I am going to guess pulling from the look of the weld.
Junior Welder
    BC Canada
Ok thanks. As far as I know, I can’t adjust the contact tip recess on my gun. But I do try to hold a tight arc
Junior Welder
    BC Canada
Warrenh wrote:Are you pushing or pulling and what settings are you using. Also, what gas? I am going to guess pulling from the look of the weld.
I pushed this one. The Migmaster 250 doesn’t have any digital displays which tell the volts or ipm but I can tell you what I used If that helps. C25 gas
Sometimes you can tap the internal threads on the cup in or out. I’ve also ground down the copper tip to make the adjustment.
