I have in my possession what I'm told is an original stainless 1931 Model A grill shell in need of help. There are 3 areas that have cracks that need repaired so it can be polished.
The dial calipers tell me its about .025" thick.
Has anyone done this with a TIG?
Other than probably shaping an aluminum block to pull heat out of the back side, I'm drawing a blank. I guess the most important thing might be what filler(if any) would be best for an 87 year old piece of stainless. Two of the cracks are right out in the open and will be quite noticeable if things don't go well. The other one will certainly need filler but it won't be seen.
I'll probably try and fuse it unless someone has any better ideas.
(Hopefully I was able to properly add images)
I used 308 filler and aluminum backing. At some point previously someone attempted to weld one of the cracks. Its now in the hands of the polisher
- sm1024 006 20180302_113334.jpg (93.17 KiB) Viewed 662 times
- sm1024 005 20180302_113226.jpg (75.94 KiB) Viewed 662 times
- sm1024 004 20180218_130630.jpg (59.01 KiB) Viewed 662 times
- sm1024 003 20180218_130606.jpg (67.11 KiB) Viewed 662 times
- sm1024 002 20180302_113305.jpg (80.67 KiB) Viewed 662 times
- sm1024 001 20180218_120302.jpg (60.23 KiB) Viewed 662 times
