Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
This first pipe I believe was installed by a basket weaver, badly on the piss. I had to put in a 4" dogleg to straighten it out and relieve the pressure on a flanged control valve. 1" sched 40.
Second pic is replacing a section of rusted 1/2" sched 80 pipe, about 12ft up, frustrated access on one side, treated sump water dripping down onto pipe caused my bead to freaking explode a couple of times just as I was sealing it up. I think the chemicals were crystallising into the joint causing some kind of contamination. Cut and grind.
Ferkin hot and humid heat wave that day. Beer o'clock saw me chewing cans rapidly.
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Nice repair! So that pipe was stressed 4"!!!!
Coldman
    Oz
Yep. I should've taken a before pic. Out 4" in two directions. Discovered when the solenoid valve was removed for service and the pipe sprang apart. There must have been huge force on the valve casting and flanges all that time. Absolute awful and dangerous original install. The welding done on it makes you spit as well.
    Thu Dec 25, 2014 9:25 am
    near Chicago
Amazing that they let hacks work on something that could be so dangerous if a failure ever occurred. Now they have the right man on the job. Nice work!
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
must have been scary when you separated it,...
Notapro
    Mon Nov 28, 2016 6:50 pm
    Central Wisconsin
What process did you use when welding it back together? Nice fix, I like the clamp attachments, Do you use them frequently?
Coldman
    Oz
All butts were tigged in two passes with vee prep, no land and 3/32" wire gap.
Both clamps are stronghand tools commonly used by pipe welders to align pipe joints.The lower one comes in two sizes, this one is the small vice grip clamp and is good down to 1" pipe. It grips 3/4" & 1/2" pipe but not enough gap is left between the jaws to get a tack in. The upper c-clamp has one v-mag jaw only, a little bit fiddly to get the alignment right but leaves a gap even on 1/2" pipe to tack through.
I use these clamps all the time, great time saving tools that gets the all important alignment right.
@craig
I believe the the comments when the the pipe sprung apart were something like " oh snap, that's something you don't see everyday!" followed by a brief discussion concerning the lineage of the original welder. :)
    near Chicago
Coldman wrote:All butts were tigged in two passes with vee prep, no land and 3/32" wire gap.
@craig
The lineage of original welder was the first question I asked myself.
    Thu Mar 10, 2016 11:37 pm
    Wisconsin
What was the lineage of this welder you speak of.
Farmwelding wrote:What was the lineage of this welder you speak of.
Maybe something to do with knuckle dragging?
Coldman
    Oz
We can only speculate cause we don't know his identity
Sent using Tapatalk
    Wisconsin
Coldman wrote:We can only speculate cause we don't know his identity
Sent using Tapatalk
Probably better this way. If you found out who he was he might have a problem coming his way from you.
    near Chicago
Thats' what I call "bad welders" :lol:
Probably learned pipefitting from his uncle Dad.
    Sun Oct 27, 2013 10:57 pm
Otto Nobedder wrote:Probably learned pipefitting from his uncle Dad.
Bahahaha!! :D
Coldman
    Oz
:lol: :lol: :lol:
    Wisconsin
Is there a Kentucky in every country. :D no offense to any from Kentucky.
Rick_H
    PA/MD
I live in Pennsyltucky :mrgreen:
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
At least you don't live in Fayettenam
bigfabdaddy
    Sun Feb 05, 2017 9:26 pm
    Somerset, PA
Steve S[/quote]
Is there a Kentucky in every country. :D no offense to any from Kentucky.[/quote]
I live in Pennsyltucky :mrgreen:[/quote]
Sent from my VS995 using Tapatalk[/quote]
I'm about 61 miles east of you.
Lincoln SP 175 Plus
AHP Alpha TIG 200X (on the way)
Oxy/Acetylene Torch
