The welder is going to be here next week.
I ordered Tillman gloves. The measurement chart said I should get medium, but I did not have confidence in it, so I ordered large. I figured gloves that were clumsy were better than gloves I couldn't put on. If they're awkward, I can use them until a smaller pair gets here.
I got an assortment of rods for steel, stainless, and aluminum.
I ordered E3 tungsten in 3/32" and 1/8". Also picked up a TIG finger.
Now I'm just waiting around. I have to go out of town next week, so I may have to tell UPS to hold onto the welder for several days. What a bummer.
- Chips O'Toole
- Farmwelding
Isn't that always the way it is. You have big plans and get all excited and something comes up where you can't do it. I was going to run some spray transfer and then we had the ACT and my teacher had a tack conference so that plan went out the window.
- Chips O'Toole
Here I was, all ready to start making really ugly beads.
- Chips O'Toole
My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
I held it in a drill, to turn it while I ground it. Kind of surprised it's not completely symmetrical.
- 03 03 17 first tungsten grind e3 small.jpg (24.4 KiB) Viewed 1175 times
Tungsten looks ok but you will get better penetration with a steeper grind. How you grind will become a matter of preference over time.
- Chips O'Toole
How straight is the chuck on the drill? The slightest wobble will give you asymmetry. Also, you'll find this makes very little difference. While I encourage the beginner to make all this stuff as perfect as possible so it's not a variable to question in one's first attempts, you would be stunned at the crapped-up and/or broke-tip tungstens I've finished a weld with.Chips O'Toole wrote:My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
I've been welding on some zinc coated nuts for a side project. Finished a few welds while I had blobs big enough they were touching the edge of my #7 cup. Good enough for a garden cart.
I left out the part where I have bent a few tungstens and sharpened like that in a drill and they were lopsided but welded just fine. I also pride myself on forging on with a badly dipped tungsten. The OP is chomping at the bit to get his welder so I guess we should hide the fact that we tout correct techniques here but in real life we rub tungsten on the concrete floor to sharpen it I have a bunch of stubby tungstens in my box of all varieties with the paint wore off from being through the collet so many times and I just grab one and deal with it , blissfully unaware of what it is.Otto Nobedder wrote:How straight is the chuck on the drill? The slightest wobble will give you asymmetry. Also, you'll find this makes very little difference. While I encourage the beginner to make all this stuff as perfect as possible so it's not a variable to question in one's first attempts, you would be stunned at the crapped-up and/or broke-tip tungstens I've finished a weld with.Chips O'Toole wrote:My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
- Chips O'Toole
So that's how you do it!exnailpounder wrote:The OP is chomping at the bit to get his welder so I guess we should hide the fact that we tout correct techniques here but in real life we rub tungsten on the concrete floor to sharpen it I have a bunch of stubby tungstens in my box of all varieties with the paint wore off from being through the collet so many times and I just grab one and deal with it , blissfully unaware of what it is.
The drill chuck is fine. It's just a long tungsten and a short chuck.
Last edited by Chips O'Toole on Sat Mar 04, 2017 2:01 pm, edited 2 times in total.
- Chips O'Toole
I hope you're not breathing zinc fumes.Poland308 wrote:I've been welding on some zinc coated nuts for a side project. Finished a few welds while I had blobs big enough they were touching the edge of my #7 cup. Good enough for a garden cart.
Those are ok. I do mine by hand on a Harbor Freight 3" mini grinder.Chips O'Toole wrote:My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
bigfabdaddy
- bigfabdaddy
My 2017 AHP Alpha TIG will be here tomorrow between 9:15am and 1:15pm. I work from 10am-4pm then class from 5pm-9pm. Planning on getting it set up tomorrow night then start practicing between classes so I can be a better tig welder than anyone else in the class.
Lincoln SP 175 Plus
AHP Alpha TIG 200X (on the way)
Oxy/Acetylene Torch
Oxy/Acetylene Torch
bigfabdaddy
- bigfabdaddy
What do you mean by hand? Just hold them in your fingers and give them a little rotation while you put them to the grinder? I ordered a Wen 6" grinder to be my dedicated tungsten grinder. I have yet to grind a tungsten, I will be shown how tomorrow during the class when we go over the tig machines that are sitting in the shop.Oscar wrote:Those are ok. I do mine by hand on a Harbor Freight 3" mini grinder.Chips O'Toole wrote:My tungsten arrived. I decided to throw one on the belt grinder. Does this look all right?
Lincoln SP 175 Plus
Oxy/Acetylene Torch
Oxy/Acetylene Torch
- entity-unknown
If you have a 3d printer or if you've got a school/buddy that has one then you can print a Tungsten grinder for a Dremel. I've been using this quite a bit and it works wonderfully! It's a remesh of someone else's design that was a remesh of someone else's design.
http://www.thingiverse.com/thing:1905626
Lincoln Electric AC225
Everlast W300 WaterCooler
Optrel e684x1
Optrel e684x1
bigfabdaddy
- bigfabdaddy
I have been grinding mine by hand on my bench grinder rather than loading them in a drill and it works amazingly. I got such a nice point on some 1/16 2% lanthinated it makes a super tiny weld puddle on the steel I was playing around on last night. Thanks.Oscar wrote:Yup exactly.
Lincoln SP 175 Plus
Oxy/Acetylene Torch
Oxy/Acetylene Torch
