TraditionalToolworks
- TraditionalToolworks
Wow, I was just telling Josh in another thread, sometimes I feel like if it wasn't for bad luck, I wouldn't have any luck at all...LtBadd wrote:Cast aluminum bench came my way...
I guess today was not your lucky day.
That said, looks like you manage it dandy Richard.
Collector of old Iron!
Alan
Alan
Flange sets on 1.5" nom sched 40 steel pipe. That's half of it done. I'm doing the pipe cutting also, and tolerance is +0/-0.25". Lord as my witness, I wish I could get work like this every single day.
- IMG_1969.jpg (45.07 KiB) Viewed 5035 times
- IMG_1970.jpg (59.32 KiB) Viewed 5035 times
Looks good, be sure and add that customer to your Christmas card list!Spartan wrote:Flange sets on 1.5" nom sched 40 steel pipe. That's half of it done. I'm doing the pipe cutting also, and tolerance is +0/-0.25". Lord as my witness, I wish I could get work like this every single day.
Nice workSpartan wrote:Flange sets on 1.5" nom sched 40 steel pipe. That's half of it done. I'm doing the pipe cutting also, and tolerance is +0/-0.25". Lord as my witness, I wish I could get work like this every single day.
Jakedaawg
- Jakedaawg
Dirty cast aluminum = $$$$
I'm getting $325 a piece from 3 different local marinas. Faired and painted. I do 3-5/wk.
Testing Chromoly settings in a mock cluster of 1.5" tubing for a motorsports customer. Thick to thin wall requirement on a lot of the clusters, .063/.083. Little cold in some spots, little hot in others on this test cluster, but got it dialed in nicely after a few test runs for the customer's parts.
- IMG_1987.jpg (38.73 KiB) Viewed 4320 times
- IMG_1988.jpg (35.31 KiB) Viewed 4320 times
- IMG_1989.jpg (42 KiB) Viewed 4320 times
What filler will you use? Welds look good.Spartan wrote:Testing Chromoly settings in a mock cluster of 1.5" tubing for a motorsports customer. Thick to thin wall requirement on a lot of the clusters, .063/.083. Little cold in some spots, little hot in others on this test cluster, but got it dialed in nicely after a few test runs for the customer's parts.
