This is a scale model of turtle for a fountain project. The final product will be 7 feet long and made of bronze.
That looks great, my son would love the turtle! Cool Idea, will be fun out of Bronze.
That's going to be cool. Are you going to braze it together or do the pieces attach to a frame?
Brazing and the plan is for the pieces to have u shaped brackets inside so the parts appear to be floating.exnailpounder wrote:That's going to be cool. Are you going to braze it together or do the pieces attach to a frame?
You're going to have to post a pictorial of that project ....I love that kind of stuff.Warrenh wrote:It's going in a large fountain in town and will have water spraying on it.
Ok. I will. I dont know the time frame yet but I will post pics of the stages.exnailpounder wrote:You're going to have to post a pictorial of that project ....I love that kind of stuff.Warrenh wrote:It's going in a large fountain in town and will have water spraying on it.
Plain carbon. You could contact TIPTIG USA and ask if they are doing any demos etc in your area.LtBadd wrote:Very nice Markus, would like to give that TipTIG a try. Is this stainless or maybe duplex?Markus wrote:Its been a while since last post.... However here's a power combo from today. TIPTIG and TIGFINGER!
-Markus-
jernigan78
- jernigan78
exnailpounder wrote:Very nice! I have to ask though...what is a fishing bell? When I was a kid we had little bells we clipped on our rods at night so we could hear if we got a bite...same thing?jernigan78 wrote:Did these guys last night for a coworker. Hes using them as fishing bells. 2" Stainless pipe, turned on a lathe to .070T. The top is .020T. The thin top made it a little challenging to not blow through it.
Yup. that's exactly what they are for. A lot of guys here in Hawaii are shore casters. And set the bells on the poles so they can hear when a fish hits. Welded 2 of these and 2 rock spikes for a guy at work. Nice guy so I didn't even charge him. Free practice time for me I guess. I just enjoy melting metal, and helping the guys out.
Very Nice Sam!
@Markus nice to see your still around I was wondering where you've been!
Now, unless it get's hot, you need J.D.s colored epoxy fill in that... If it does get hot, maybe a glass/ceramic?GreinTime wrote:For all you non Instagrammers out there!
And for those who are, @greintime3592 is my IG name
Steve
- GreinTime
It's a turbo Downpipe, so it'll get pretty hot!Otto Nobedder wrote:Now, unless it get's hot, you need J.D.s colored epoxy fill in that... If it does get hot, maybe a glass/ceramic?GreinTime wrote:For all you non Instagrammers out there!
Steve
So, even filling it with SiBronze and buffing it off might not stay...GreinTime wrote:It's a turbo Downpipe, so it'll get pretty hot!Otto Nobedder wrote:Now, unless it get's hot, you need J.D.s colored epoxy fill in that... If it does get hot, maybe a glass/ceramic?GreinTime wrote:For all you non Instagrammers out there!
Steve
Oh, well. So much for that idea.
Steve
A steel lifting fixture, a little bit of MIG and mostly TIG
- laser cut components
- 20170512_123422a.jpg (63.43 KiB) Viewed 2863 times
- tacking
- 20170512_132702a.jpg (41.42 KiB) Viewed 2863 times
- MIG Lincoln PowerMIG 180 DV
- 20170515_105212a.jpg (61.04 KiB) Viewed 2863 times
- One of the finished parts
- 20170516_082957a.jpg (38.86 KiB) Viewed 2863 times
- Red and Blue
- 20170515_105821a.jpg (73.03 KiB) Viewed 2863 times
Nice Rich, whats it lift?
- MosquitoMoto
Some lovely work showing up here lately guys.
You people have skills to be truly proud of.
Moz
Moz
Nothing particularly nice or even TIG but I wanted to post here to ask you guys: after learning, becoming comfortable with TIG and only doing that for a while, did anyone else find their MIG technique changed? I'm finding that on 1/8" and thinner sheet metal, I'm MIGing like TIG, in that I'm stacking hot tack welds. I find it lets me use a lot more heat without flooding in a pile of wire to keep from overheating the joint. Ends up giving me a nice flat bead profile with piles of penetration and low heatsoak. In the pic below, the two fresh pieces are joined with a few continuous runs but the rest is all this approach I described above.
- strut tower.jpg (45.96 KiB) Viewed 3152 times
Trying a different way of mitering for the first time.
3mm 6063 welded with 3/32 4043 filler and 125 amps torch switch only, 150 Hz and 35% EP
Little grainy but I just wiped off the Sharpie lines with acetone, no other cleaning.
- IMG_20170522_36797.jpg (35.86 KiB) Viewed 3118 times
- IMG_20170522_27988.jpg (30.64 KiB) Viewed 3118 times
- IMG_20170522_23250.jpg (25.24 KiB) Viewed 3118 times
Thx Richard
Here it is done with styro-foam cladding
Will be used for noise supression of a pump.
- IMG_20170522_3347.jpg (44.31 KiB) Viewed 3092 times
