I think that was a mis-placed post, possibly meant for Aleksi'a topic.
- Wiredwelder
It's from tapatalk, it's confusing , I apologize , but they change stuff all the time on this app. I was trying to post to Otto nobedder, about the -423 liquid nitrogen vessel he was fixing. (Post #50) It was a old post, but some how my setting got changed and it went to the oldest post instead of the newest. Sorry guys!
- Wiredwelder
Somewhere between the app and putting the rats to bed I got distracted! Still haven't figured out how I did it!
That's why I pursue leaks as small as the nanoliter range-- Any flaw that causes a leak, regardless how small, can grow.Wiredwelder wrote:Is the vessel subject to shrinkage with the extreme temperature differences ....seems to me that much temperature difference from the ambient temperature, even a small leak could cause a hot spot, and build on itself till it ruptured?
Just thinking.
The vessel, whether hydrogen, nitrogen, oxygen, or argon, stays at one temperature for 5 years (barring trouble), until ASME retest.
- Wiredwelder
I'm no engineer...was just thinking about it, a lot of what I read on hear helps me to figure out things. Like that post you made when you were welding stainless the other day that said mash the pedal, fill the rod, and go. (In the mig like tig thread) Classic! You know what they say ....pay attention, you might learn something!
I pay attention every time I'm here.
There's always something to learn. I've been doing this about 30 years, and this forum constanly reminds me how much I don't know...
Now welding Aluminium tank what is been modify.. Welds are made ESAB MIG 3000 Aristo and ESAB wires... I have started to like weld Aluminum at overhead and vertical more then steel.. I was suprised how well it goes when ewerything is correct.. Tank has new bottom vessel and one more section then before..
- IMG_1709.JPG (103.24 KiB) Viewed 2311 times
Aleksi86,
Your fab work and welds are really good! So you like the ESAB machines? I have a friend who likes them and their wires a lot. I have only ran their mig machines with solid wire in them, but it did run good.
Question- do you whip with the aluminum mig? looks like it is whipped or pulsed. Not asking because it is right/wrong just curious as to how you are doing it. On my Lincoln 350MP's it has the Pulse on Pulse feature that gives you that nice look and was just wondering if these ESAB's have something similar. Keep up the great work.
THanks a lot man
Here we weld allmost allways ESAB,KEMPPI, Both good machines.. I weld litle bit aluminium at my previous job whit LINCOLN 300 or 350 Aluminium if i recall right?? Its a pulsed machine ESAB, but thoos riples are made By weawing some eeees) If you have douple pulse its good feature to have..But other important thing is gun Angel and that your contact tip is not too out at gas nozzel, (i keep more at inside at AL) so it wont get too hot. (so you dont keep too long stickout because your tips gets too hot and lose Argon coverage) Thoose welds are deasent looking
but the main thing my work is that it will hold pressure/liquids inside with out leaking.. I just wanted to ensure that it would pass test By weawing litle at sides to prevent any porosity or something? And im only a beginner at welding Aluminum ( just a short time welded AL) But its a nice material when you know how to work whit it
THERES A NEW TANK TOMORROW..
![Neutral :|](./images/smilies/icon_neutral.gif)
Otto Nobedder wrote:"TANKS" for the undate...
Looks great!
![Image](https://farm6.staticflickr.com/5044/13901552265_27cbbbed7c_c.jpg)
![Image](https://farm6.staticflickr.com/5049/13901585235_c815818b0b_c.jpg)
![Image](https://farm4.staticflickr.com/3736/13901497463_7c4ba420bf_c.jpg)
Does it have to be welded? How about brazed?
![Image](https://farm4.staticflickr.com/3723/13901461105_d4e4da714a_c.jpg)
![Image](https://farm4.staticflickr.com/3826/13901490905_e9b2a06eb0_c.jpg)
I've not welded it yet, but found THIS today, in a vessel head.
Waiting on information from engineering. There's a cause for this, and a fix that must be applied before I repair it.
- GEDC1225.JPG (169.35 KiB) Viewed 2555 times
- GEDC1229.JPG (160.36 KiB) Viewed 2555 times
I have to tell you I'm getting a little jealous. Your job looks and sounds like fun.. keeps the wheels turning in your head. well maybe just in mineOtto Nobedder wrote:I've not welded it yet, but found THIS today, in a vessel head.GEDC1225.JPGGEDC1229.JPGWaiting on information from engineering. There's a cause for this, and a fix that must be applied before I repair it.
Steve,
Is that crack from pressure or a stress crack from movement?
The information I've gathered so far, says this is the result of a design flaw. The inner tank's front support is on the outside of this crack, and only a small part of the designed support is in contact. This is stress cracking, from too narrow a load area supporting the vessel during transport (this is, as usual for my work, a semi-trailer).Superiorwelding wrote:Steve,
This project is on hold, pending drawings for the fix to the original problem. I've also been advised to expect a similar crack on the opposite side, about the same distance from center, for the same reason. If one is present, it's not leaking yet, but I'll have to investigate anyway.
Once we perform the fix of the root cause, I can then make the repair(s) at the crack(s).
That is exactly why I like this job. My brain is engaged at least as much as my hands. It occasionally gets tedious, but rarely gets boring. Also, the experience and instinct I've developed has my boss' respect, so I usually get to proceed in the manner I prefer, rather than following directions.jimbob wrote:I have to tell you I'm getting a little jealous. Your job looks and sounds like fun.. keeps the wheels turning in your head. well maybe just in mineOtto Nobedder wrote:I've not welded it yet, but found THIS today, in a vessel head.GEDC1225.JPGGEDC1229.JPGWaiting on information from engineering. There's a cause for this, and a fix that must be applied before I repair it.
Steve SThere are times when I feel like a bit of a robot at work, one of the reasons I like coming on here just to read what everyone else is up too. And a big thanks from a new guy for helping keep it like that!
And, yes, it IS fun.
We have allso cracks to repair 2-5 times a week if trailer is run up something? Or sterss crack is appear somewhere inside.. I have repaired only couple but can say that ITS NOT EASY JOB TO DONE MOST TIMES... When you have round surface under your feat and wobbly stand on boards.. And hole/crack is at top in sealing..Then you need to be JEDI or realy consenrate what you are welding and to be steady hand..And there is all kind of contaminy inside that crack.. But feels good when your boss understands that it was no easy weld/repair to do. And shows hes
appreciation for you to have job done.
scottwelder1371
- scottwelder1371
Stainless air vent for custom skylight on the Timex HQ.
- IMAG0301.jpg (29.83 KiB) Viewed 2379 times
- 1396391946145.jpg (41.64 KiB) Viewed 2379 times
- IMAG0296.jpg (52.63 KiB) Viewed 2379 times
SBblacksmith
- SBblacksmith
This is a front door that I made a little while back. Stainless steel frame with silicon bronze panels welded to the frame.
Finally got the picture upright.
- Finished door. Ss and bronze
- image.jpg (42.91 KiB) Viewed 2632 times
- Welding up a ss frame for a front door
- image.jpg (56.29 KiB) Viewed 2639 times
Sweet!
I'll admit to a brief "WTF?" moment, until I realized the image was on it's side...
Nice work!
Nice work!
SBblacksmith
- SBblacksmith
Yeah, I don't know why it loaded that way. It was really the first project where I had to force myself to get comfortable in out of position and overhead tig welding. I have Jody's videos to thank for that.
SBblacksmith
- SBblacksmith
One last post before I go to bed. These pics are a few months old but I am proud of them. One is a really nice ss hand rail we did in a house the other was a personal project I did to test my tig skills welding .030 ss to .030 bronze
- Ss and bronze tacked together.
- image.jpg (62.07 KiB) Viewed 2636 times
- Book cover ss and bronze
- image.jpg (62.26 KiB) Viewed 2636 times
- Ss hand rail tig welded in place in the finished house
- image.jpg (30.78 KiB) Viewed 2636 times
