sky
thanks for the tip.
is that a general rule or something you
figured on your own?
Craig, check out the u bend cutting fixture from Cone Engineering.... Simple and effective.
http://www.coneeng.com/tech_assist.html
I've bought tubing and collectors, I'm going to buy that guide when I'm ready to fab my turbo headersmotox wrote:rick
thank you, interesting site!
have you ever used any of their
products?
Just a repair on a small piece of our liquid filling equipment, 316L small double bevel, .035" filler...
- IMG_20160404_220106.jpg (64.08 KiB) Viewed 1726 times
AFR_Autoworks
- AFR_Autoworks
Just working on some 4" oval exhaust for a drift car. Tons of stainless practice.
- image.jpeg (43.88 KiB) Viewed 1795 times
- image.jpeg (48.69 KiB) Viewed 1795 times
- image.jpeg (56.27 KiB) Viewed 1795 times
- big gear head
AFR_Autoworks
- AFR_Autoworks
It's really not as time consuming as you would think. There was allot of weld time and back purging involved but as for cutting, I have a good bandsaw which has cut my time at least in half. I can setup a cut, while it is cutting I debut and tack the previous piece.
AFR_Autoworks
- AFR_Autoworks
Got it all welded up today. Pretty happy with where my welds are at but I could still use some more practice. Also, my back purge could have used a bit more flow.
- image.jpeg (42.06 KiB) Viewed 1676 times
- image.jpeg (60.27 KiB) Viewed 1676 times
- image.jpeg (54.64 KiB) Viewed 1676 times
- image.jpeg (49.89 KiB) Viewed 1676 times
- image.jpeg (48.13 KiB) Viewed 1676 times
- image.jpeg (69.11 KiB) Viewed 1676 times
AFR_Autoworks
- AFR_Autoworks
On a side note, anyone know how to rotate pictures? Every time I upload from my phone they are sideways
If you are using photobucket ,I believe that there is a flip in the edit part of it.Poland308 wrote:Tried that too sometimes it works sometimes not. Just thought though I haven't tried cropping it first.
Thespian is just an old username I have used forever , my name is Bill
Little repair job 304L...not fun when you find someone did a previous repair with silver solider instead of welding... Makes damn mess.
- Damn silver soldered joint after striking and arc
- IMG_20160408_171822.jpg (53.61 KiB) Viewed 1937 times
- Finally got it to take some filler
- IMG_20160408_172842678.jpg (49.38 KiB) Viewed 1937 times
- Finished
- IMG_20160408_173539951.jpg (54.29 KiB) Viewed 1937 times
Whipped up a bracket for a printer cleaning station for one of our lines...actually made 4 custom brackets depending on where they were mounting.
- IMG_20160408_233452708_HDR.jpg (45.37 KiB) Viewed 1883 times
- IMG_20160409_212417200_HDR.jpg (49.27 KiB) Viewed 1883 times
- IMG_20160409_212357149_HDR.jpg (44.29 KiB) Viewed 1883 times
No that is how they are run on the Furick FUPA 12 set-up...LtBadd wrote:Nice work as always Rick, BTW did you bow the screens in the gas lens yourself?Rick_H wrote:Whipped up a bracket for a printer cleaning station for one of our lines...actually made 4 custom brackets depending on where they were mounting.
AFR_Autoworks
- AFR_Autoworks
Today, I did the first "paying job" for our new company. It's simple stuff, but was urgent and I got paid well to do it on Saturday. For simplicity, I put it on my facebook wall.
https://www.facebook.com/steve.scott.39 ... 309&type=3
Member or no, it should let you see the pictures, as I have no privacy settings on it. At least it "used" to work that way.Coldman wrote:I'll have to take your word for it Steve as I don't do facebook.
Vic.
I suppose I could put it in dropbox or on the cloud...
[edit] Screw it. I'll upload a few directly.
- DSCF0018.JPG (74.53 KiB) Viewed 1622 times
Not sure how I uploaded that one, since I hit "reply" before I opened the file..
Here's the new bracket that replaced the previous turd.
- DSCF0027.JPG (56.27 KiB) Viewed 1623 times
