Had to chop out a couple of 3" refrigeration ammonia stop valves and replace with stop/check valves.
The replacement valves were shorter in both dimensions so the first job was to weld on pups.
Left hand valve welded in.
Setting right hand valve in position and adjusting gap.
All welded out.
Nice Markus was that machine or hand?
If welding on a vessel we purge for 10min with nitrogen. If pipework first we pump it down to a bit of vacuum then break with air and get into it. If there is oil present (often) it will have disolved ammonia which gases out into the weld and welder. This is where inexperienced welders put on their skirts and run away screeming. I've been sucking it for 35 years as a fridgy and since I've been welding I get calls from all over for crap jobs nobody wants to touch. Is this a niche? Anyway you don't want ammonia in your welds. This happens when valves don't hold - it happens. The arc and gas shield glows green like the hulk, the tungsten starts to disappear and you get severe porosity in your weld. Alot of cursing happens about this time. To seal off a butt we weld a socket on the pipe upstream from the joint to let pressure and flow out while we complete the butt and then screw a plug or valve into the socket.
I watched a mate of mine weld a 12" leg into the underside of a horizontal vessel with oil and ammonia running out through the joint. He used 5p for root and 7016 out. That joint got xray ultrasonic and mag particle and passed all. Awesome job. Gobsmacked.
- MosquitoMoto
Thanks coldy. If my current job goes tits up (possible) im heading straight to our local Refrigeration company, that does welded systems.
- TRACKRANGER
KYNgsx
Welcome to the Forum
Tell us a bit about yourself in Member Introductions if you like.
Neat work too!
Trev
Neat work too!
Trev
Last ones for this week.
Chip B by Mike Zanconato, on Flickr
I am crying in my cups!
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
- MosquitoMoto
Pure weldporn.zank wrote:Last ones for this week.
Kym
Nice work, as usual, Zank!
Nothing special here... I am trying out a new camera. It's a bit of a cheapie, but it doesn't have 30 features I'll never use.
Just some basic pipe fab. First pic in standard mode, second in "macro" for close-ups. We'll see how they come through on the forum.
- DSCF0002.JPG (118.65 KiB) Viewed 2127 times
- DSCF0005.JPG (73.69 KiB) Viewed 2127 times
The temps like to steal the sanitation tooling we have at the lines so I fabbed up a lockable holder..of course in stainless.
- IMG_20150917_214617867.jpg (34.54 KiB) Viewed 2271 times
- IMG_20150917_214607803.jpg (33.92 KiB) Viewed 2271 times
- TRACKRANGER
Good one Rick. Does the job nicely!
Semi trailer.Poland308 wrote:Like on a semi trailer or a skid for set up somewhere?
I knew Len would recognize them...
