Hello!
After spending some time on youtube watching people build nice tables with lots of storage, tool holders and stuff,
i decided to make a really basic one:) Maybe i'll add just one or two holders for vicegrips;)
I'm going to add a detachable part that will be used as cutting-area but i will post that later..
measurements for tabletop are: 10*800*1250 (mm)
jockewahlstrom
- jockewahlstrom
- image.jpeg (64.75 KiB) Viewed 1944 times
- image.jpeg (63.03 KiB) Viewed 1944 times
- image.jpeg (44.56 KiB) Viewed 1944 times
- image.jpeg (66.3 KiB) Viewed 1944 times
- image.jpeg (39.09 KiB) Viewed 1944 times
- image.jpeg (47.64 KiB) Viewed 1944 times
- perfect 90 degrees :)
- image.jpeg (39.34 KiB) Viewed 1944 times
*TIG Welder : Stahlwerk 200P S AC/DC, 200Amp (german brand)
*MIG Welder : Big A*S old Kemppi, i don't know the model.
*Plasma cutter: Pela Cut 70P, 70A machine (cuts 20mm)
*Stick welder: Kemppi Minarc 150A
*A bunch of grinders and handtools.
Excellant work.
Timmontoya88
- Timmontoya88
I would have never thought of adding bolts to help leveling the table. I'll keep that in mind when I upgrade to a weld / cutting table.
Thanks!
Thanks!
jockewahlstrom
- jockewahlstrom
First of all; THANK YOU EVERYONE!Timmontoya88 wrote:I would have never thought of adding bolts to help leveling the table. I'll keep that in mind when I upgrade to a weld / cutting table.
Thanks!
The leveling bolts are really helpful.. You can't tell by the pictures but i have welded a nut on the other side and i use the one shown in the pics as a counter nut to lock the bolt in place:)
Timmontoya88
- Timmontoya88
Ahhh now I really get it, I should apply that to my table I recently made (Out of scrap).jockewahlstrom wrote:The leveling bolts are really helpful.. You can't tell by the pictures but i have welded a nut on the other side and i use the one shown in the pics as a counter nut to lock the bolt in place:)
I don't have pictures of mine, but I threaded some half inch plate that capped the legs. Then welded the bolt to a plate used to mount some heavy duty casters. My nut locks into that half inch plate.jockewahlstrom wrote:First of all; THANK YOU EVERYONE!Timmontoya88 wrote:I would have never thought of adding bolts to help leveling the table. I'll keep that in mind when I upgrade to a weld / cutting table.
Thanks!
