Steel storage rack for garage
Posted: Fri Jan 01, 2016 1:18 pm
by Malooga
Does anyone know where I can find a plan for a metal storage rack? I'm looking for something that would hold angle, square and plate - it would go along the long wall of my standard garage bay and I was told to bolt to the floor so it doesn't topple over on the wife. Can't stick out too far or won't be able to get the car in.
Suggestions would be much appreciated,
Alex
Re: Steel storage rack for garage
Posted: Fri Jan 01, 2016 10:56 pm
by Bobby Sixguns
![steelrack.jpg](./download/file.php?id=8323&sid=cdfb3d541b44c17aab1d9dcd84b05d7b)
- steelrack.jpg (55.34 KiB) Viewed 4868 times
This is a rack I made out of stuff I had laying around, main legs are 2.5"x 2.5" square tube .25 wall. The arms/shelves are 3" C-channel. Hope this gives you some ideas, sorry the picture isn't any better.
Posted: Sat Jan 02, 2016 5:04 pm
Malooga wrote:Does anyone know where I can find a plan for a metal storage rack? I'm looking for something that would hold angle, square and plate - it would go along the long wall of my standard garage bay and I was told to bolt to the floor so it doesn't topple over on the wife. Can't stick out too far or won't be able to get the car in.
Alex
More then likely the stand you need is custom to your situation, best to sketch it up yourself.
Posted: Mon Jan 04, 2016 9:22 am
by little_sparky
something like this do the job?
![Image](http://s13.postimg.org/eqhb1x1t3/692f3fc532d0ffd3bbfb6ca0933896de.jpg)
Posted: Mon Jan 04, 2016 9:34 am
by Rick_H
You could also anchor it to the wall depending on what the garage is made out of... If you can keep it off the floor it is easier to clean around and under.
Posted: Thu Jan 28, 2016 1:33 pm
by Angusbass
Very nice. I'm looking for ideas as well.
Posted: Mon May 23, 2016 9:44 pm
by brucepts
Here is a rack I built for my garage that would fit between the wall and the garage door track. It is only 14" deep 60" wide and 60" high
I made it so I could adjust the shelves up or down if I needed to add more space, I used pvc fence rails for separation of stock not the most cost effective but did maximize material storage separation space. The area under the shelves allows me to store large stock vertically and I am adding drawers under the smaller shelf (where you see the trays now) for small stock storage. I'm currently working on a rack that will sit on top for longer stock storage based on conventional front loading stock racks.
In the plans now is a small sheet stock rolling rack that will sit on the near end of this rack that will hold a limited amount of flat material that I have on hand.
Posted: Tue May 24, 2016 4:56 am
brucepts wrote:Here is a rack I built for my garage that would fit between the wall and the garage door track. It is only 14" deep 60" wide and 60" high
Very nice!
Posted: Fri Jul 08, 2016 9:08 pm
by Wolfgang
Here is my contribution in regards to tubing racks. Its mobile and has worked well so far!
Front for tubing, back for sheets and plate.
![Image](http://i296.photobucket.com/albums/mm189/wolfraidermn/Bike%20Shop/Tubing%20Rack/20150213_150921.jpg)
Posted: Sun Aug 28, 2016 9:12 am
by bearston
Hey brucepts, I really like your rack idea to help keep small quantities of varied material. Don't know why I didn't think of this before, very practical and perfect for the garage. Consider the idea stolen, mua-ha-ha!!
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Posted: Sun Aug 28, 2016 11:08 am
by MinnesotaDave
Mine is just rectangle tubing with angle welded to it.
Think of a ladder - mine sits on the floor, leans against the wall. Bolted to floor and wall.
Posted: Sat Sep 03, 2016 8:28 pm
by brucepts
bearston wrote:Hey brucepts, I really like your rack idea to help keep small quantities of varied material. Don't know why I didn't think of this before, very practical and perfect for the garage. Consider the idea stolen, mua-ha-ha!!
No prob, here for sharing glad it helps someone out
