hey guys,
I am building some metal steps and I would like some suggestions on how to control some warpage. All the steel is HR carbon steel, laser cut and 1/4" thick. The issue I am having, at least in the demo I made up for the customer is the plate that will be receiving the mohagany boards is warping. Now some of it was attributed to the shear cut from my supplier, but you can see where I welded it warped some more.
Template I built for customer approval
Here is a picture the customer provided as what they wanted as a final product
I am welding with Lincoln mig 180. I weld from the outer edges to the center of the support.
I look forward to your suggestions.
Rob
P.S. I will post pictures as the project progresses
This man here is the best at building staircases.
Check the end of the thread for the completed pics.
http://weldingweb.com/showthread.php?42 ... highlight=
Artie F. Emm
- Artie F. Emm
I can't get to the youtube link that AKWeldshop suggests (from this location). Would a different type of brace weld differently, and give a more favorable warp situation? I see all those triangular openings under each tread and all I can think is: stuff will get in there. Dust, carpet fuzz, lint. Or in my house, small toys. If it rains on Easter Sunday, a great place to hide eggs for the indoor egg hunt. Not sure what that alternate design would be so I can't suggest anything better right at this minute, just thinking out loud.
Dave
aka "RTFM"
aka "RTFM"
@AK weldshop,
Cool link, the steps he is making are bent and those edges will help battle warpage. (in my experience). Really nice welds as well
@ Artie fin
HAha, true. Everything will get caught in the triangles. I left some distance from the stringer to help battle that. Also this isn't my house and I won't be cleaning it.
Thanks guys...I appreciate the feedback.
Rob
@ Artie fin
Rob
- Braehill
spkrman,
Since you've already welded a few you should be able to find the average deflection with a straight edge. Take a heavy piece of angle, maybe 3 x 3 x1/4 the length of the stringer and place a strip of metal (key stock comes to mind) whatever thickness the average deflection measured, plus a little, right in line with the weld on the top side and clamp the ends to the angle with a c-clamp. This should give the stringer the same amout of preset that will offset the warpage. Hope this makes sense.
angus
- angus
if you are lagging them in or bolting get a piece of wood and try fastening and see if they pull in.
after welding all risers, flip, hit plate with three pound hammer, check with straight edge.
clamp a piece of angle, as has been suggested but you probably would not even need the spacer.
don't particularly like the way the wings are tied into the stair but I am not climbing them.
probably would have had them formed in one piece so they laid across the square tube. like a wing. either precut for
angle of rise or cut to fit myself.
is it my aged eyes or is that stair in the photo all out of whack. or is it the pic? it's making me dizzy.
I was considering doing a second pass on the opposite side. Basically a blank pass to help correct the warp page. I have seen that done several times. Anyone have any experience with that?
Rob
Rob
Here are some pictures of the stairs and how they have progressed.
The metal has a 1.5" thick Mohogany tread on each one.
The finish is sandblasted with a coat of clear coat on each section.
- 2nd view of the stairs installed
- Stairs 2.JPG (26.79 KiB) Viewed 1549 times
- 1st view of the stairs installed
- Stairs.JPG (27.85 KiB) Viewed 1549 times
This will work fine.Braehill wrote:spkrman,
If you want to correct after welding - take your oxy fuel torch and run an orange line on top of the plate where the weld is.
This will pull the plate up as it cools - pulls to the side your torch was on.
Check out this video "Mr. Shrink" for a little about why it works.
http://youtu.be/2vuGlcbDwKY
@ Len
I welded the opposite side of the original weld. I didn't want to do the preload method as I figured there would be inconsistencies with the set up (and my patience).
Step one (Verify the warpage)
Step 2 ( A line to guide my weld. I purposely went in the opposite direction of the first weld. Thanks Jody for the video on warpage)
Step 3. (All the welds done)
Step 4. (Grind off the welds...)
Step 5. Result!!! BooYAH
Went pretty good and added about the time I estimated. That doesn't happen to often. I am usually WAY off LOL
Rob
- The initial warpage
- Stairs crooked.jpg (28.89 KiB) Viewed 1511 times
- Line to guide the weld
- Stair chalk line.jpg (26.92 KiB) Viewed 1511 times
- Stairs with all the welds to straighten
- Stairs welded to straighten.jpg (27.27 KiB) Viewed 1511 times
- The straightening welds ground off
- Stairs welds ground off.jpg (32.64 KiB) Viewed 1511 times
- The result
- Stairs straight.jpg (27.75 KiB) Viewed 1511 times
Rob
Here are some pictures of the project through the build
The view from the top
The view from underneath
This is the powder coating from the paint shop. Sandblasted and cleared with a gloss finish.
- View from the top of the landing
- Stair view from top.jpg (27.14 KiB) Viewed 1509 times
- View from underneath
- Stair view from underneath.jpg (33.66 KiB) Viewed 1509 times
- Painted stairs
- Stairs paint finish.jpg (42.79 KiB) Viewed 1509 times
Not sure yet. I know there will be glass involved but not sure of what look he wants. I told them I am interested in building the railing but not if they want every weld polished.
Got any suggestions?
Rob
Rob
Not really my area of expertise, but a free standing glass panel would fit your floating tread set up. Ones ive seen have a stainless post with clamps to hold the glass sheets.
superclarkey
- superclarkey
