    Tue Jan 07, 2014 9:06 pm
    Elizabeth, WV
I am anticipating a new welding table build in my future. I want to get everyone's opinion of things you liked things you didn't like when building a table. I am thinking about pull out draws for tools and a shelf. Want everyone to throw out ideas. Keep it within 24"x 48".
Matt
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
One thing I can say with certainty is DO NOT WELD ON TOP MORE THAN YOU HAVE TO!!! I have built several tables and finally on the last one I smartened up and just stitched very, very lightly to hold the plate to the frame. This table came out as flat as it could.
One suggestion is when you make the frame, leave enough room to allow the clamps you will use to clamp your parts down without hitting the frame. The drawback to this is if you weld the table plate to much on the frame, it will warp down. Another can be hammering to hard could bend it slightly.
I put nuts on the legs to allow a bolt head to level it out when necessary.
I am sure there is more, will think of them and post up.
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
"Right 0n" about table top/frame welding,warping ,hammer bending, clamping room
leveling with a cushion/non slip, quieter and does not mar floor,
expensive, but for the finicky ,works
http://www.mcmaster.com/#standard-level ... ts/=t9xm0c
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
    Elizabeth, WV
I never thought about a way to level it, thanks for that advice. I was thinking about putting pull out drawers on one side to put my wire brushes, raking hammer, ball peen hammer, and other useful tools but after the clamp suggestion I may throw that idea out or drop the drawers down a little to make room. I thought about casters on the bottom of the legs for portability in the future. The building I am in now would be tooooooo small to move it around in but later when I get the shop I want with a concrete floor in it to where I can roll it from job to job then it might be a great addition. I don't know just thoughts. Keep em coming. :)
Matt
    Mon May 12, 2014 12:06 am
    Downey, CA
I have seen trailer hitch balls used for adjustable welding table feet...
Glen
    Elizabeth, WV
GlenC wrote:I have seen trailer hitch balls used for adjustable welding table feet...
Like :)
Matt
    Tue Jul 01, 2014 4:34 am
    Skiatook, Oklahoma
That's actually a damn good idea.
[THUMBS UP SIGN]
danielbuck
    Tue Jan 21, 2014 7:56 pm
    Gilroy, CA
I think a large bolt would be cheaper?
    Downey, CA
Large bolts may be cheaper, but the chrome trailer balls look cool!
Glen
    Downey, CA
here is an interesting foot
Glen
    Eddy, TX
Well, all this table talk has me wanting to start a new build!! I mentioned it to my wife and all I got was the eye roll and a reminder of how many tables I already have. I still want to do that alum table a well as a "designer" table, something that looks high end.
    Elizabeth, WV
Well I guess if you want a high end table I might be able to make time for you and build it for ya. :lol:
Matt
    Eddy, TX
Matt,
I am not sure if I can afford your work, I am just a poor weldor ;) :lol:
    Elizabeth, WV
I am not judging your welding skills, and I easy to work with. :lol:
Matt
    Eddy, TX
In all honesty, I am thinking of picking up one of those portable tables. Mine are always covered in junk and the theory is I can set it up and put it away and it will not be covered in my junk.....we will see.
    Elizabeth, WV
Harbor freight has a decent looking portable table for a decent price.
Matt
    Eddy, TX
That's the one I am thinking about buying. I have read others reviews that certain components are cheap so I am not sure yet.
    Elizabeth, WV
I have looked it over and like Jody says, what can go wrong? ;)
Matt
    Elizabeth, WV
Here's an update on the welding table.
Matt
Too---o nice.
Not meant to be used to work on ;) 8-)
Everlast 250EX
    Elizabeth, WV
I added for swivel casters (locking) and I have flat bar on the other end for hanging angle grinders on. If you can't see it, I wired up an outlet box with 4 plugs and 6' of cord with a 110v plug so I can wheel it around and plug in anywhere and have power for tools.
Matt
