Anyway, the top is 26x36" 1/4" steel, the tubing is mostly 1.25" square tubing 1/8" wall, and a bit of flat bar and angle iron. Good thing I made the casters bolt on, after I loaded it up with weight, I found that the pneumatic casters I had didn't really work so well, so I switched them out for some larger semi-soft solid rubber wheels. And compared to my old cart, since this one is considerably wider, I wanted to also make it taller, so that working on things while standing up, I'm not stooping over all the time. And if I want to sit down, I have a stool that's high enough to sit down and still work on the same height table.
Drawers and places to hold things are a must, my garage is small, and my hope is to keep everything welding and grinding related on the cart. And to make matters worse, my garage is kind of full right now, with stuff that normally isn't in there. Parts for other people's vehicles and projects that we haven't had time to finish and clear out of there, it's getting tight!
It's mostly finished now, but here's the progression. Now, I'm just going to use it for a few weeks and see if there's anything I need to add or modify, once I'm fairly happy with it, I'll remove everything and paint it.
Tungsten grinder on the side, flashlight holder, angle grinder holders, power strip, and other stuff. I debated on putting my bench grinder and small bandsaw mounted to the side of the cart, but I figured they would probably just get in the way more than anything, and they would take up my valuable table top realestate. (not to mention making all kinds of metal dust all over the cart!) So, they will be mounted on a work bench or stand elsewhere.
![Image](http://404photography.net/wip/cart_01.jpg)
![Image](http://404photography.net/wip/cart_02.jpg)
![Image](http://404photography.net/wip/cart_03.jpg)
![Image](http://404photography.net/wip/cart_05.jpg)
![Image](http://404photography.net/wip/cart_06.jpg)
![Image](http://404photography.net/wip/cart_9.jpg)
![Image](http://404photography.net/wip/cart_10.jpg)
![Image](http://404photography.net/wip/cart_11.jpg)
