Converting Hobart TIG cooler pump to a quiet one
Posted: Thu Jan 23, 2014 12:40 pm
by Tjschur
Re: Converting Hobart TIG cooler pump to a quiet one
Posted: Thu Jan 23, 2014 12:43 pm
by Tjschur
To see the videos go to youtube and search Tjsnordic
There are many vids there on the TIG cooler conversion. I did not want to post them all here.
Hope this helps others wanting to do this.
T.J.
Posted: Sat Jan 25, 2014 10:41 am
by TamJeff
I find that the noise of the cooler is more pleasant than people dropping metal or trying to talk to me while I am welding. I guess it mostly depends on what size facility you are working in, but I find the sound of the square wave or the inverter to be much worse on AC, and the cooler helps mask that some. Nice bit of work there at any rate. That should last a life time.
ETA: I am wondering now if our cooler pumps were replaced at some point because all I hear is the fan, which sounds like yours in the video.
Thanks for posting this. I am sure some will find it useful because the Bernard cooling systems are hard to beat and are worth rebuilding IMO if one can find a worn out one at a deal.
Posted: Sun Jan 26, 2014 5:02 am
Hey,
Our electricians replaced the pump on one of our bernard coolers recently, and it went from the loudest piece of junk you ever heard to so quiet that you cant even hear it in a normal shop environment. Whish they had done it years ago,
Posted: Mon Jan 27, 2014 8:51 am
by Tjschur
TamJeff wrote:I find that the noise of the cooler is more pleasant than people dropping metal or trying to talk to me while I am welding. I guess it mostly depends on what size facility you are working in, but I find the sound of the square wave or the inverter to be much worse on AC, and the cooler helps mask that some. Nice bit of work there at any rate. That should last a life time.
Thanks TamJeff,
I hope this helps others with coolers that originally have Oberforfer pumps in their coolers. This set up is at my home shop for my Dynasty 300DX machine.
T.J.
