Here are some pictures of a machining job where I had to weld in a shaft. This weld was done with an HTP tig set on arc at 100 amps.
- Shaft pressed in
- 20131229_073942.jpg (24.1 KiB) Viewed 1299 times
- Hub machined out
- 20131229_072006.jpg (48.79 KiB) Viewed 1299 times
- All broken parts
- 20131229_063636.jpg (47.18 KiB) Viewed 1299 times
- Machining to size
- 20131229_080715.jpg (36.33 KiB) Viewed 1297 times
Rob
- Welded up
- 20131229_074443.jpg (40.26 KiB) Viewed 1297 times
- All repaired
- 20131229_093355.jpg (43.24 KiB) Viewed 1297 times
Agreed.
Precision work like that is always challenging... Puts your brain to work, as much as your hands.
Steve
Steve
