Page 1 of 2
3rd Hand
Posted: Sat Feb 16, 2013 5:15 pm
by Nils
Used an old hand-sledge we found out shooting. Came out okay.
Re: 3rd Hand
Posted: Sat Feb 16, 2013 5:20 pm
I like that a lot!
That's a solid base!
Re: 3rd Hand
Posted: Sat Feb 16, 2013 9:33 pm
by TamJeff
Very handy indeed. Nice looking weld to boot.
Re: 3rd Hand
Posted: Thu Feb 21, 2013 2:27 pm
by ArcherAndy
I really like that idea! I have been wanting to try and build a 3rd hand. Very resourceful use of materials.
Re: 3rd Hand
Posted: Sat Mar 02, 2013 3:52 pm
by noddybrian
Ok - slightly different outlook on the 3rd hand thingy ! I'd never worried too much about it , but recently when altering a mirror finished stainless steel part it arced badly on the bench & made me say " DARN " ! so the hammer head was laying under the bench as was the 1/2" & 3/4" square - I figured making it touch at 3 points would be naturally more stable & the hammer head can be slid up & down to excert more weight if needed - the feet are rounded in 1 direction but flat across giving more choice - their clad in copper sheet to improve conductivity - I also bolted a bit of 1/4" flat copper on to "light up on" after grinding the tungsten as I manage to sweep them off the bench otherwise.
Re: 3rd Hand
Posted: Sat Mar 02, 2013 4:10 pm
That's sweet! I like the sliding weight.
Do you have the copper bonded to the steel in any way? Solder, or something?
Re: 3rd Hand
Posted: Sat Mar 02, 2013 4:20 pm
by TamJeff
Great idea.
Re: 3rd Hand
Posted: Sat Mar 02, 2013 4:28 pm
by noddybrian
Yes- the copper is soft soldered to the legs for conductivity - but could be changed if necessary.
Re: 3rd Hand
Posted: Wed Mar 06, 2013 8:57 am
by Nils
Way too cool! Very creative and clever! I like it!
Re: 3rd Hand
Posted: Wed Oct 16, 2013 9:59 pm
by Weber Sarge
Here is one I made last winter with a sliding weight -
The tip and ground faces on the round tubing are copper building wire that were tig welded directly to the steel , then turned down in the lathe . No more arc marks on work , big help for sure .
Sarge
Re: 3rd Hand
Posted: Thu Oct 17, 2013 8:48 am
by noddybrian
Nice job - I like the sliding weight - looks good.
Wish I'd had more copper around when I made mine but it's not a material I really work with - had just a few offcuts of sheet under the metal shear so that had to do.
Glad to see someone else with a lathe - began to think I was the only member with one ( actually it's several plus Milling machines etc - someone recently called me a "low buck Keith Fenner" !! not sure how to take that & I don't have the weird beard thing going on ! )
Re: 3rd Hand
Posted: Thu Oct 17, 2013 12:34 pm
by Braehill
Brian,
I too have a small hobby lathe, very handy.
Re: 3rd Hand
Posted: Thu Oct 17, 2013 6:41 pm
by AnvilJack
Very impressed with the sledge hammer third hand, but I can't resist commenting that the steel in a sledge hammer is (usually) high carbon content, and is very, very useful. I have even seen one used as an anvil for knife making. Ah well, you know where it is if you need the steel for something else. Well done.
Re: 3rd Hand
Posted: Fri Oct 18, 2013 12:41 am
by wquiles
noddybrian wrote: Glad to see someone else with a lathe - began to think I was the only member with one
Same here, I got a small lathe (12x36) and work with Aluminum, Delrin, Steel, and Titanium:
Re: 3rd Hand
Posted: Fri Oct 18, 2013 5:38 pm
by blaz
I see a 6 jaw chuck there. That will be my next chuck I think. Any issues?
I have a 14"x40" coulchester and a 13"x30" harrison. I love the coulchester, great machines.
Re: 3rd Hand
Posted: Sat Oct 19, 2013 11:48 pm
by wquiles
blaz wrote:I see a 6 jaw chuck there. That will be my next chuck I think. Any issues?
No issues, and so far for the work I do, my adjustable Set-Tru (0.0002" TIR), 6.25" Bison 6-jaw is THE best upgrade (the DRO being the second) I have done to my lathe.
Re: 3rd Hand
Posted: Sun Oct 20, 2013 7:40 am
by Ranger
LOL wish I had the room or even the money but when I can afford it I want my own machine shop and complete welding setup with plasma cutters and a 4'x8' CNC plasma table too
Re: 3rd Hand
Posted: Sun Oct 20, 2013 10:50 am
by wquiles
I come from the "other side". I am already a machinist, with a small machine shop (lathe, mill, accessories, etc.) and I am now starting on the welding, but it will take a long time and a LOT of saved money before I can have a "welding shop" :o
Will
Re: 3rd Hand
Posted: Sun Oct 20, 2013 9:58 pm
by Responsible
I built this one when I was practicing 'T' joints. Made setting up easy.
Re: 3rd Hand
Posted: Tue Oct 22, 2013 9:38 pm
by Weber Sarge
noddybrian wrote:Nice job - I like the sliding weight - looks good.
Don't sweat the copper issue - it's just building wire stripped and sanded clean , it was "good enough" for a third hand project . I've got a nice old Enco 12x36 , a bit sloppy but for most of what I need it works great .
Sarge
Re: 3rd Hand
Posted: Thu Oct 31, 2013 1:02 am
Hey,
I finally got around to making some 3rd hand tools. 1 monster, 1 smaller and 2 matching (sort of) ones,
Re: 3rd Hand
Posted: Thu Oct 31, 2013 3:55 am
by AnvilJack
Muscle men.
Good on you, Mike.
Re: 3rd Hand
Posted: Thu Oct 31, 2013 6:38 am
As Jody has said, There's no kill like over kill.
Re: 3rd Hand
Posted: Thu Oct 31, 2013 6:59 am
by MinnesotaDave
I like them :)
When I did mine, I noticed they would still make small black arc strikes on my aluminum. Jody showed the same and used silicon bronze for the ends I believe.
I did not have any so I used house electrical wire and tigged some copper on mine :)
Re: 3rd Hand
Posted: Thu Oct 31, 2013 7:31 am
Thats the next step for me too.
