Metal Manipulator
- Metal Manipulator
Not a whole lot of changes, mostly unnoticeable things. I changed out the tail light so I had to fill where the original one was and build the plate and light holder along with the bracket to hold it to the fender. Made a bracket for the front signals. Shorten the tail pipe and made a bracket to mount the heat shield. Put a drain plug in the tank for oil changes. Also with cutting the pipe down I had to add a mount to the pipe and modify the original frame mount bracket.
- IMG_20150911_123336182_HDR.jpg (3.11 MiB) Viewed 9951 times
- IMG_20151111_102510044.jpg (2.4 MiB) Viewed 9951 times
- IMG_20150911_114755254~2.jpg (1.95 MiB) Viewed 9951 times
- IMG_20150826_151607235.jpg (3.78 MiB) Viewed 9951 times
- 20230728_101646.jpg (3.15 MiB) Viewed 9951 times
