Aluminum boxes
Posted: Fri Mar 03, 2017 10:41 pm
I have been playing around with a sheet metal brake on some 16 gauge diamond tread aluminum building everything from toolboxes to dog boxes. Thought I'd share.
The Forum
https://forum.weldingtipsandtricks.com/
https://forum.weldingtipsandtricks.com/viewtopic.php?f=9&t=11247
It only smokes for about 3 seconds then it goes out. I actually caught on fire the other day and burnt my shirt off of me.exnailpounder wrote:That dog box is really cool. Nice work! Ever lit that wood floor on fire?
mcoe wrote:It only smokes for about 3 seconds then it goes out. I actually caught on fire the other day and burnt my shirt off of me.exnailpounder wrote:That dog box is really cool. Nice work! Ever lit that wood floor on fire?
I was overhead aluminum tig welding and got right to the end and I nipped the filler rod and it dropped on my shouldsr and put me up in flames.exnailpounder wrote:mcoe wrote:It only smokes for about 3 seconds then it goes out. I actually caught on fire the other day and burnt my shirt off of me.exnailpounder wrote:That dog box is really cool. Nice work! Ever lit that wood floor on fire?I lit a shop rag soaked in carb cleaner on my bench the other day. I could smell it burning and I knew what was happening but the weld looked really good so I didn't want to stop
ATTA BOY!mcoe wrote:3 second degree burns the size of a nickel. I finished the rest of the welds then doctored it lol
Whatcha the opening at the cuff of a button up shirt, I was tigging a long bead and I slid my arm up on the piece and found that opening when I ran it across the bead lolFarmwelding wrote:Fun fact-if you are oxy fuelwelding and aren't wearing sleeves, be careful don't roll the filler wire onto your arm.
Or if you are using an abrasive chop saw and want to protect a lathe behind it from sparks don't use a cotton welding shirt-it lights up fast with all the Sparks.
You know the definition of insanity is doing something repeatedly and expecting different results. I guess burning ourselves over and over again makes us all insane. You'd think we'd figure out that metal is usually hot and sharp and the tools that cut them are sharp and the tools that cut them and weld them produce a lot of heat.mcoe wrote:Whatcha the opening at the cuff of a button up shirt, I was tigging a long bead and I slid my arm up on the piece and found that opening when I ran it across the bead lolFarmwelding wrote:Fun fact-if you are oxy fuelwelding and aren't wearing sleeves, be careful don't roll the filler wire onto your arm.
My hands get dried out and the skin sometimes cracks near my nails and same thing...don't even notice til I soak a rag with acetone.....then I notice!Otto Nobedder wrote:I'd rather have a welding burn than a paper cut any day. The paper cut, I'll forget until the parts cleaner hits it...![]()
