Page 1 of 2
Filler rod holder cart(s)
Posted: Sat Jan 28, 2017 11:23 am
by electrode
Re: Filler rod holder cart(s)
Posted: Sat Jan 28, 2017 2:59 pm
Looks good, do the tubes pull out?
Posted: Sat Jan 28, 2017 3:05 pm
by exnailpounder
Theres something wrong with some one that is that organized...must be a machinist
Posted: Sat Jan 28, 2017 4:17 pm
by Rupes
LOL ... I didn't see lower bit of the bottom picture without scrolling. I WAS gonna say if you're truly organized you won't use a sharpy to write on the contents but buy a Dymo labeler or such and print labels
Looks great though. I made something similar but a single column of about 6 tubes. Outgrown it some time ago and need to revisit
Posted: Sat Jan 28, 2017 4:19 pm
by electrode
LtBadd wrote:Looks good, do the tubes pull out?
Nope, the first part of the assembly was pvc cementing the lower cap in place.
Posted: Sat Jan 28, 2017 4:20 pm
by electrode
exnailpounder wrote:Theres something wrong with some one that is that organized...must be a machinist
Yes, that and every other thing it seems. I am the "Jack of all trades, master of none" guy.
Posted: Sat Jan 28, 2017 4:24 pm
by electrode
Rupes wrote:LOL ... I didn't see lower bit of the bottom picture without scrolling. I WAS gonna say if you're truly organized you won't use a sharpy to write on the contents but buy a Dymo labeler or such and print labels
Yeah, I had my wife write on the caps on my first one as I would have screwed it up somehow with a mistake or sloppy printing or a sharpie that had a flattened fat tip.
Then I got the Brother P-Touch and that thing is great. I will make labels for the first one too when I get around to it.If I went down to the shop right now to do that, about 20 other things would happen and when I got there I would forget why I went down there..
Posted: Sat Jan 28, 2017 4:30 pm
by exnailpounder
I have to dig through the tubes on the back of my welder where I have my 308, 309, 316 and 347 all neatly shoved into the same tube. I get to try to read that little stamp on the rod. Or I go to my tube for ER70, ER80 and SilBr all mixed in...I have grabbed a SilBr rod , thinking it was ER and only noticed when I lit up. My floor is clean though
Posted: Sat Jan 28, 2017 4:32 pm
by Rupes
Its my new years resolution to be more organized and stop throwing shit in boxes.
I started labeling contents and organizing into job types. It is pretty nice to walk in and find something in 10 seconds. I thought I was just being nerdy about it all till I saw some of those Festool guys.
Posted: Sat Jan 28, 2017 4:40 pm
by exnailpounder
Rupes wrote:Its my new years resolution to be more organized and stop throwing shit in boxes.
I have tried to organize and I have gotten better but when I get busy and focused on something, I will set something down, and I tell myself that I need to remember where I set it down, and completely forget where I set it 5 minutes later. I lost my aluminum brush and have been losing my mind looking for it...I never pay attention to it until I need to weld aluminum and then can't find it...like yesterday...I need to stop getting old
Posted: Sat Jan 28, 2017 5:22 pm
electrode wrote:LtBadd wrote:Looks good, do the tubes pull out?
So what do you do with a 1/2 or even 3/4 of a rod, if you put it back into the tube you won't be able to get it out??
Posted: Sat Jan 28, 2017 5:26 pm
by exnailpounder
LtBadd wrote:electrode wrote:LtBadd wrote:Looks good, do the tubes pull out?
He sends them to me and I weld them back together and use'em
Posted: Sat Jan 28, 2017 5:37 pm
by electrode
Yes, getting old does suck...But here is what I do with the short pieces.
- Dscf2895r.jpg (60.31 KiB) Viewed 2041 times
Never mind the rust on the welding table as I have yet to clean it up again, but I made a little ground clamp attachment (not pictured) that works pretty well but is a work in progress.
Posted: Sat Jan 28, 2017 5:39 pm
by exnailpounder
I'm stealing your railroad spike third hand idea and claiming it as my own
Posted: Sat Jan 28, 2017 5:40 pm
by electrode
exnailpounder wrote:I'm stealing your railroad spike third hand idea and claiming it as my own
I am going to have to make a phone call.
Posted: Sat Jan 28, 2017 5:49 pm
by exnailpounder
Posted: Sat Jan 28, 2017 7:28 pm
by Rudy Ray
Now why would a welder use wood to make anything?
Posted: Sat Jan 28, 2017 7:43 pm
by exnailpounder
Rudy Ray wrote:Now why would a welder use wood to make anything?
Maybe cause he's a goddamned machinist posing as a welder
Posted: Sat Jan 28, 2017 10:40 pm
by Rudy Ray
exnailpounder wrote:Rudy Ray wrote:Now why would a welder use wood to make anything?
Now why would a machinist use wood to build anything?
Posted: Sat Jan 28, 2017 11:31 pm
by electrode
I had a lot of wood left over from building some cabinets for my wife and I didn't have any steel laying around.
Posted: Sat Jan 28, 2017 11:32 pm
by electrode
Rudy Ray wrote:exnailpounder wrote:Rudy Ray wrote:Now why would a welder use wood to make anything?
Because he used to be a woodworker. Actually being a jack of all trades gives you many options. I bought my first TIG welder in June of 2008 and that is when I built the first filler holder (out of wood). I may have done it before the machine was delivered or shortly after. I built the second one to match the first one.
I do powder coating too but I don't powder coat everything.
And I built my own powder coat oven but not out of wood. I did build the spray booth out of wood though.
Posted: Sun Jan 29, 2017 1:34 am
by Rudy Ray
Just giving a hard time. As a welder, you should expect no less out of me.
Posted: Sun Jan 29, 2017 10:38 am
by electrode
Rudy Ray wrote:Just giving a hard time. As a welder, you should expect no less out of me.
I knew that.
So you use filler rod for tooth picks?
Posted: Sun Jan 29, 2017 2:05 pm
electrode wrote:Rudy Ray wrote:Just giving a hard time. As a welder, you should expect no less out of me.
I knew that.
I use a .040 pure tungsten, myself. One end is pointed, the other ground flat like a screwdriver. Works great!
Posted: Sun Jan 29, 2017 2:33 pm
by electrode
Otto Nobedder wrote:electrode wrote:Rudy Ray wrote:Just giving a hard time. As a welder, you should expect no less out of me.
I knew that.
I figured somebody was gonna say that...
This guy used thoriated:
- jaws.jpg (25.62 KiB) Viewed 2429 times
