There's an XMT 300 cc/cv on my local craigslist, pretty beat up, the guy was asking $600, brought it down to $500...but it's the same type deal...do I really need another welder just to have a better stick welder? I don't think so...but there's an Idealarc 250 for $75 I was looking at...again, I think it's the same thing...do I really want yet another welder? Especially a bit 400 lb. transformer machine?sbaker56 wrote:It's probably the best stick machine I've ever used, although I'm not sure how qualified I am to judge between it and the XMT 350 at school
I'd much rather of had that Invertig 275-S like you have.
I don't think you should feel cheated on the tig, to be honest, I suspect it will tig weld just fine it just won't provide you HF start.
Nothing wrong with that, you can still tig weld. The problem with tig is that it's a can of worms in the sense you need an argon tank, you need a flowmeter, you need tungstens and a way to sharpen them, you need filler for the type of welding you want to do...it just opens up a lot of expense. Now, once you get over that initial fall off the cliff, then all you need to do is learn how to move your torch hand while feeding filler and operating the pedal...
That's the thing I like about stick...it's a stinger and a ground and an electrode. That's all you need. My i-Tig 201 weighs 28 lbs., toss it over your shoulder with the strap and away you go...stick welding is so much easier...now learning to watch and read the puddle is another story...
If I was you I would keep my eyes open for a valve torch and a pedal, if nothing else you can get a pedal from SSC for about $160, I was checking recently when that 275-S was listed last week. Lift start is preferred for much of the auto work as well.sbaker56 wrote:I'm sure my machine will tig weld quite well enough for my purposes, especially given the foot pedal option. But had I expected it to be more than primarily keeping in practice at home or while tig welding my own things, I'd probably want the additional tig features of the Primeweld over anything else too.
In your case you don't even need another machine, yours will do tig just fine.
