Just thinking out loud but if it was possible, I'd flip every other truss to alternate stresses on the equipment. provided the equipment is built to do that... also if they aren't using the whole 16', maybe run the truss a few feet in from one side or the other.
That might help. But there’s an automated truss stacker outside that needs trusses to come out as consistently as possible. So they do their best to feed the truss in exactly the same way every time. So yeah, pretty tough on that roller.varekai wrote:Just thinking out loud but if it was possible, I'd flip every other truss to alternate stresses on the equipment. provided the equipment is built to do that... also if they aren't using the whole 16', maybe run the truss a few feet in from one side or the other.
Here’s some of the stuff they make.
BillE.Dee
- BillE.Dee
my brother got hooked up with some fella who uses spent propane tanks of all sizes to make rollers for farms. Brought a 20 foot tank to the farm, mounted the arms and cut a little 10x10 hole and filled it with concrete. After the tractor pulls the roller over the farm, the ground is FLATTTTT and no stones...either drove them back into mother earth or crushed them. I really hope you discover the problem with the roller.
BillE.Dee
- BillE.Dee
holy enchalatas...been waiting for you to get back on that roller repair. Have you gotten hold of that old one to investigate? And just wondering if the skinny kid came already built into the new rollers.
I could get it, but I’m not sure I want a 5000 lb paperweight rolling around my shop. I’m sure it’s simply a matter of an under welded part. And as soon as it cracks outside, the inside baffle will crack loose as well. And no matter how you weld and reinforce the outside, if the inside baffle is lose, the outside won’t last. If these new ones don’t last I’ll be surprised.
Beats me, I may or may not have heard screaming and kicking from inside the rolls. Hard to tell with a 1” thick wall
Even if they built up the size of the fillet on the weld it’s unlikely they ground out a bevel for full penetration. The unwelded root will still lead to cracks.
