Sanford
    Sun May 24, 2015 8:45 pm
]somehow I managed to snap the arm of my backhoe
Some backracks I made for an f350
made this small bin to hold my poker and shovel for my wood stove but I think it would serve better as a battery box or something on my 53 ford. I was dying to try out some aircraft style rivet on a project
When we moved to a house with a 2 car garage I decided to make this larger table 1/2" plate with 3x3 1/4 wall uprights, I used an idea from Kevin Caron on youtube for the feet. Trailer balls to level the table out and also to lower it onto caster to move it (if need be)
Here's a 1940's Lincoln SA200 I overhauled years back, I wanted to keep it but just had no use for it.
sa200 28.JPG (57.72 KiB) Viewed 2136 times
sa200 24.JPG (93.1 KiB) Viewed 2136 times
sa200 2.JPG (79.42 KiB) Viewed 2136 times
Aluminum trailer ramps, nice and light
    Thu Dec 25, 2014 9:25 am
    near Chicago
Nice work! I like the trailer ball idea. I gotta know...how did you break your hoe that bad? Oh Welcome to the forum!
    Sat Mar 30, 2013 11:49 am
    Sweden
Nice box
Aluminum, copper and rivets will never be wrong together, thumbs up
    Sun Oct 27, 2013 10:57 pm
Cool stuff - welcome :)
Sanford
I honestly don't no what happened with the hoe, I turned around while I was moving it and found that. I was removing stumps at my house at the time and its pretty rocky here so that must have done it. Thanks
Sanford wrote:I honestly don't no what happened with the hoe, I turned around while I was moving it and found that. I was removing stumps at my house at the time and its pretty rocky here so that must have done it. Thanks
Looking at where it sheared, I'd guess there was a weld discontinuity at one of the inboard/lower corners (Either undercut or crater-cracking) that allowed a crack to start. Once started, it can't be stopped unless by some chance you see it on inspection.
Looks to be an excellent repair, BTW.
lwhaples
    Thu Apr 30, 2015 6:22 pm
Nice repair.Really like the table and the feet.Never seen that for leveling.Kinda cool !
Bill Beauregard
    Thu Jan 24, 2013 9:32 pm
    Green Mountains of Vermont
The hoe is surprising how thin the steel is. Who's product is it? Usually they break where a thumb is attached. This doesn't seem to have one.
plain ol Bill
    Wed Apr 08, 2015 6:46 pm
    Tenino, WA
Really nice looking SA200 - likely the best self contained welding machine ever made. Most of them are still running today.
Tired old welder
CNC plasma cutter
Colorful shop w/
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Even some of the terribly ratty looking ones.
