Hey guys,
I`m new to the forum so first of all HI
Now to my question:
I have to weld a box with the following measurements:
29x17x9 inches with the material being 3/8 inches thick. It`s going to be welded with 7018 electrode.
Is there any data or if you have any information on the correct sequence of welds to prevent or at least minimize distortion?
- TRACKRANGER
Owr,
Hi, and welcome to the forum.
Do you need to weld inside and out?
When you say 'Box', will it have 6 sides welded (i.e. is it a sealed cube?)
The most important thing to reduce distortion is to tack it together initially, by getting good fit-up and stitching it together with plenty of distributed tacks. Then go about welding all of the sides, again with staggered welds.
if it's sealed you'll have to take some consideration for internal pressure issues.
Others will chime in with great ideas too, hopefully.
Trev
Trev
Welcome. I agree with using plenty of tacks and staggering your welds. I'd just like to add my emphasis to the importance of proper fit up. In my experience the fit up and joint prep was the key to a good result. Good luck and let us know how it turns out.
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Weld it all up except for (1) spot, maybe 1/2" long.
Let the whole thing cool to room tempature.
Than weld up the last bit.
Stagger your welds, but it won't warp much.
Best regards,
~John
Best regards,
~John
Well, it`s all welded and there is almost no warpage. I welded the corners first and then welded the center part of the longer side then moved to the shorter side. I welded those welds from the center out to the corners and moved diagonally for the next weld.
Then flip it over, repeat and eventually weld the rest on the longer side moving to the corners. That`s all folks
- Box3.jpg (79.79 KiB) Viewed 2531 times
- Box2.jpg (51.29 KiB) Viewed 2531 times
- Box1.jpg (35.35 KiB) Viewed 2531 times
- TRACKRANGER
Are we allowed to ask what's it for?
I'm sure it's just my eyes playing tricks, but in the first photo it looks a bit like a crack near the top of the vertical weld.
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
I will back you up, looks like it to me as well.xwrench wrote:I'm sure it's just my eyes playing tricks, but in the first photo it looks a bit like a crack near the top of the vertical weld.
- Braehill
I think they're talking about to the left of your circle. It looks like the slag may have puked down over your other weld.
It`s just metal poured over from the heat. It was grinded out and welded over with no problem whatsoever. The part under the bulge on the left is actually millscale. Should of grinded it before welding and use 3/32" instead of 1/8" but wanted to weld a bit hotter on the corners. A crack that size wouldn`t of disappear after using flap disk on it just to deburr.
Don't take this crack question as your project is bad. Looks very good to me. Just thought that this looks like a crack. Pic is blurry but this is what I was referring to.
- image.jpg (90.11 KiB) Viewed 1621 times
I never thought of it that way. Back to the crack it is actually a millscale, but the picture is not of good quality so maybe that`s why it looks like it. As I said earlier, crack like that doesn`t disappear after using flap disc on it just for deburring the edge. The tie in wasn`t perfect so there was a little undercut on the sides but nothing major since the weld is already overdone for it`s application.
Since we are already talking about weld cracks here are some pics of cracks on aluminum gates for track&field. The wind caused the gates to break.
- 9.jpg (24.78 KiB) Viewed 1612 times
- 8.jpg (30.13 KiB) Viewed 1612 times
- 7.jpg (41.58 KiB) Viewed 1612 times
- 6.jpg (54.26 KiB) Viewed 1612 times
- 5.jpg (47.32 KiB) Viewed 1612 times
- 4.jpg (80.36 KiB) Viewed 1612 times
- 3.jpg (49.04 KiB) Viewed 1612 times
- 2.jpg (29.32 KiB) Viewed 1612 times
- 1.jpg (27.65 KiB) Viewed 1612 times
Agreed! Serious "lack of penetration" issues. Those welds all appear to be (poor) cap/crown welds on metal that was not prepped for the weld.dsmabe wrote:Looks like weld material just sitting on top of everything.
Sounds like a good hobby. I'm always scrutinizing welds when out and about. Drives my friends nuts!Owr wrote:I just like to take pictures of welds that are interesting to me. Sometimes you should just use stick for stainless:
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Post well and truly hijacked.
- 2014-01-24_15-06-54_309.jpg (47.62 KiB) Viewed 1448 times
That fun-house mirror pic of you does, I suppose, qualify as a hijack...weldin mike 27 wrote:Post well and truly hijacked.
I can`t remember how many times I have seen fences welded outside with a tig procedure. People pay lots of money for sth that is not really safe to use.
I remember one time when one of the construction sites supervisor was explaining to me how he sent some welder off the site because he was welding ss pipes with stick - outside. He said then we did it the proper way - with tig, of course without any wind protection.
