ImLow78
    Fri Aug 22, 2014 9:22 pm
    In a state of confusion.
12' dia 1" thick welded in 5g with .068 NR-233
Shannon
ImLow78
Vertical up
root, hot, cover and cap.
Shannon
ImLow78
Flat
hot, cover and cap.
Shannon
ImLow78
Now for the POOP that I was left to fix after a first time welder (with NR-233) decided to go a little to long before asking for help.
Shannon
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Well Shannon, all I can say is that I'm sure impressed with the gargantuan size of this project. Some serious runs involved there boy.
How many rods / packets / lbs do you reckon were required to complete a full joint around the circumference including root passes and cap etc?
PS: I don't envy you having to fix the under-cut and the slag inclusion....
Trev
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
Sure is a beautiful day in your neighborhood!
In photo #4, what is the purpose of the 2" (or so) welds that are perpendicular to the main weld joint?
Dave
aka "RTFM"
weekendwelder70
    Tue Dec 17, 2013 4:16 pm
    Salem, OR
I am thinking they are left behind from bar that was welded on for lining up the two pipes.
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
how are you planing on fixing those bad welds, girding?
ImLow78
TRACKRANGER wrote:Well Shannon, all I can say is that I'm sure impressed with the gargantuan size of this project. Some serious runs involved there boy.
Trev
Trev,
In just welding the cans together there was 21 rolls of wire used. We still had to laminate some 2" thick plate for lifting eyes on the end sections (on the side of the cans) and lifting eyes on the top side of the cans.
Artie F. Emm wrote:Sure is a beautiful day in your neighborhood!
What's you see is the reminence of welds where we placed the "dogs" on the cans to push and pull the joints around to get them to align.
What we use is a piece of 1" thick plate that is cut in the shape of an "L" with a 2" bolt that has the nut welded to the plate that is used for clamping and pushing force.
motox wrote:how are you planing on fixing those bad welds, girding?
This one was with scarfing tip and a 8" grinder but I have had to use a air arc before.
Also keep in mind guys that cap pass is roughly 2" wide. LoL
Those cans are 30' long and we was making the five cans into two sections because the drilling company didn't get a large enough crane to lift it in one piece. (Each can weighed 48,000 lbs.)
Shannon
Awright....
If I've got to scroll through 30+ pictures of your weldsto get to the point,
Here's a play on your topic title...
https://www.youtube.com/watch?v=CNj-wu3mE3c
8-)
Shannon, what will the pipeline be used for?
Some serious capacity there...
ImLow78
TRACKRANGER wrote:Shannon, what will the pipeline be used for?
Coal mine air shaft that just had a fire in a old works. This is just the surface casing. Once it's set and concreted in the ground they will drill another hole through that string of cans to shaft depth. Once they pop through we will start running 8' dia in the ground to the mine.
When it rains it will have enough air pushing out of the hole to suspend water in mid-air.
Shannon
    Wed Sep 17, 2014 8:19 am
@ImLow
Which clamps did you use?
I always use chain clamps http://www.dwt-gmbh.de/en/pipe-chain-clamps.html but don't know if it's the best solution for that size
Greets from Germany, Achim
ImLow78
CutKiller wrote:@ImLow
Achim,
I don think that type of system would work for this size of pipe. I'll be going back to finish the job next week. When I get there I'll shoot some photos of the "dogs" we use.
Shannon
    Sat Jul 06, 2013 11:16 am
I've always been impressed with the simple key plate, lug and wedge system used in building large tanks and welding sections of large pipe. Once installed you can use the wedges to either open or close the gap as you progress and change the alignment in and out.
The only downside is the fact that they need to have the key plate lug welded to the surface that will later need removed with a torch and grinder. This proves to be a little more troublesome when dealing with SS or Aluminum but in the age of the plasma cutter it is getting easier.
@shannon
that would be great, looking forward to it
greets achim
ImLow78
CutKiller wrote:@shannon
greets achim
This is what we call a "dog". With this piece you can align your joint. The check marks on the outside of the cans that was asked about is where there was a dog welded on to get that joint aligned.
Shannon
That is what I call a "screw-dog". I also have "wedge-dogs", which are quite similar, only a wedge is driven where your threads and nut are. For plate work, I FAR prefer the wedge dog for speed and efficiency. For pipe work, the screw-dog can't be beat.
I also have "gap dogs", that I tack 120* apart on pipe to push/pull the gap to where I want it.
ImLow78
Otto Nobedder wrote:That is what I call a "screw-dog". I also have "wedge-dogs", which are quite similar, only a wedge is driven where your threads and nut are. For plate work, I FAR prefer the wedge dog for speed and efficiency. For pipe work, the screw-dog can't be beat.
It's amazing the amount of pressure you can exert with that little bolt. But I've also had them pop off and bite me. Had three stacked tight and as soon as I felt the weld give on the one I was tightening I couldn't get away fast enought. Blew all three off and took one to the chest. Needless to say I don't crank on them to that point any longer. I just add more dogs to help distribute the work load over a larger area.
(*photo addition edit*)
This was the job I was dodging dogs. We cut the first can to get it to root gap right and after that every joint was a PITA to dog and we cut every can after that. Never heard if the can sequence got screwed up or if it was just a poopy string of cans.
Shannon
