anthonyfawley
- anthonyfawley
My old rig was basically a f350 single cab pick up with my welder thrown in the back, so for me , im ridin in style. let me know what you think. took me a little less than a week, still a few things to add. I build and pipe in irrigation pump stations for golf courses, hence the large bed.
Last edited by anthonyfawley on Mon May 31, 2010 12:40 pm, edited 1 time in total.
Were you the one that built the bed, or just mounted it on the truck ??
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
anthonyfawley
- anthonyfawley
built the bed from start to finish. (except tool boxes, bought those). I used 6" channel for the outer frame, 4" channel for the cross members spaced about every 12", 3" structural channel running the lenght of the frame, Full 4' x 8' x 1/4" sheets of tread plate and 2" square tubing for the rack and rails.a 2' X 8' X 1/4" steel tread plate for the back as a work area. for the bumper i used 3" channel for a frame and sheeted it with 1/4" tread plate. Mounted it to the frame with 3/8" x 4" flat stock welded to the bed and bolted to the frame. I used a U-bolt by the fuel tank to mount to the frame. Made me nervous welding to close to it. The actual dimensions of the bed are 10' long X 8'-5" wide. It is a wide sucker but has proven handy.
Anthony
Anthony
A most excellent job I must say.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
anthonyfawley
- anthonyfawley
mister bobo
- mister bobo
anthonyfawley
- anthonyfawley
Let me know, that would be no problemmister bobo wrote:I am jealous-that looks finer than froghair split 2 ways! I may steal your plans for my 97!
billyolds
- billyolds
that is sick! great looking beads as well! Just found this site but stoked to see a few poeple at least down here in what i saw in another thread as "the rich mans state" lol im over the tampa bay area.
It is what it is...
whiskeyriver
- whiskeyriver
whiskeyriver
- whiskeyriver
rick_barter
- rick_barter
This is awesome, man! How do you figure out how and where to put the mounting stuff? I'd love to see your plans or pictures of the full progression. Very inspiring!!!
rvb
rvb
anthonyfawley
- anthonyfawley
Ultralow787
- Ultralow787
Anthony,
Now that is the work of a skilled craftsman! You have every right to be proud of that!
Perfection is impossible, but if you strive for perfection, excellence is obtainable!
1983 Canox "Sparkler" 225 AC Stick Welder
Hobart 210 MVP MIG Welder
Harris "Spitfire" Oxy-Acetylene Set
