    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Loaded up the welder, leads, extension cord, helmet, rods, and chopsaw....
Going to be putting shelves and racks in truck boxes....
Gonna be a little while, lots of fabbin and fittin.
Enjoy,
~John
    Palmer AK
To be continued....
Pics will explain, hang with me,
~John
    Mon Mar 10, 2014 6:49 pm
    Michigan
Work on trucks much? Looks like several belt tensioner in the bucket
Sent from my DROID RAZR HD using Tapatalk
    Palmer AK
I work on most anything....
But the shop I went to, used to be a heavy equipment shop, and there's lots of parts around.
That's why I was hired to put shelves in these connexs....
More pics tonight.
~John
brokeitagain
    Tue Feb 11, 2014 1:16 am
where the hell are these pics man, I have been waiting all damn day :)
    Palmer AK
brokeitagain wrote:where the hell are these pics man, I have been waiting all damn day :)
One hour.
Man!!!!
These pics are worth waiting for!!! 8-)
Go figure.... ;)
~John
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
...Patiently waiting... :D :D
    Palmer AK
Making some of these little "pad eye-hooks"....
Dirty way of doing.
Why rush me??? I get paid by the hour. ;)
    Palmer AK
You get some of the drift.
~John
    Palmer AK
4inch by 3inch, 1/16 wall tubing.
Used what was around.
It'll work.
This pic is 3inch by 3/8 thick flat bar, used to cap the ends of the tubing.
I'm telling you, It'll work. :D
    Palmer AK
Got them pretty close, 4x3. :)
Cutting the tubing to make it fit in the truck box....
87 and 3/4 inches.
Love that saw.
    Palmer AK
Capping the ends of the tubing.
1/16 wall tubing, to 3/8 flat bar. :?
1/8 8010 @ 70amps.
Then I'll weld the little "pad-eye-hooks" to the cap plate.
    Palmer AK
Dead nuts square!!!
I mean square. ;)
Now the hard part, welding.
Are you sure you want to see this???
Tacked the hooks on, and checked it for fit.... :|
    Palmer AK
Just needed a little cutting/grinding....
    Palmer AK
Fits like a glove.
The shelf in the tubing is for the plywood, when I get the other one in.
This box is 20ft.
I have 3 other 40ft ones to do, little bit different....
These connex's are full of engine parts ETC!!!!!
It is begging for shelves, lots of wasted space.
Gonna be taking a while, its a part time job, I work on it when I have time.
~John
    Palmer AK
Got a bunch of work to do on this rig to....
Mr. fixits are never out of work, if your willing to get dirty and do the tough jobs.
~John
    Michigan
IH or ford?
    Palmer AK
ejpoter wrote:IH or ford?
It's a 50s Ford Major....
It has some problems.
I'll get some pics of them.
~John
    Thu Jan 24, 2013 12:13 pm
Unusual to have 4wd - is that a conversion or a factory fit by whoever built the loader - not seen one quite like it - " Roadless " amongst others sold a 4wd kit here - fairly rare now as most were exported to " bongo" land many years ago - they fetch good money now if you can find one & a clean 5000 or 7000 makes silly money - first tractor I drove regularly was a super Major - real luxury with electric start after the petrol / TVO high major ( E27N )
    Palmer AK
It's a special model.
Got a Shawnee loader system on it.
Had a bad knock, I never heard, but the guy said it so bad, we shouldn't start it.
So, took the oil pan off....took a whole day to get it off.... Nothing...
Two bolts, and the valve cover was off.
Look and behold!!! One of the valve springs was compressed and stuck down.
So.....
I'll be working on it tomorrow.
-John
    Michigan
Sounds like you need access to a valve grinder and seat grinder.
    Palmer AK
ejpoter wrote:Sounds like you need access to a valve grinder and seat grinder.
That's no problem....
In your opinion, should a guy go through and grind all the valves???
This one valve, we beat it down and pried it back up for a while, so it moves freely.
Was thinking of topping her of with atf, running it for 20mins, than drain it, and then 15-40....
Since you sound like an engine man, whats your take on it???
Man!!! hi-jacking my own thread.... :?
~John
    Sun Feb 17, 2013 1:30 pm
    Colorado
John- If it were me the next step is pull the head. The cylinder you found the collapsed spring in probable has a piston top that looks like you took a chipping hammer to it. (if it even still has a top) Check (mic) the crank and plastic-gauge the bearing on the rod too. Check the wrist pin. This kind if thing can do a lot of damage you can't see with your naked eye my friend.
Send the complete head to a machine shop if you don't have the tools and do the valves, seats, guides and seals. A set of springs would be a good idea too., (others may be getting ready to go)...If you don't it WILL be back to haunt you.
Back to our regularly scheduled program.
    Michigan
Well that would be proper. But I your case I bet there isn't much for engine shops around. And the guys that use this porbebly don't use it every day?
If they don't I would pull the head and check the top of the cylinder for any damage. That old of a machine shouldn't be a tolerance motor. With that the valve. Unless the spring was broken there would be no problems.
So me I would get by checking all valves with the head off and only do what's needed. Unless its an everyday machine with a ton of hours. With a stuck valve and good spring I doubt it. Just my opinion on a farm type tractor.
    Palmer AK
I'll check into it, and let you know.
~John
