Well ,when ya got a new welder you just gotta have a new cart and old idea just don't work. Here's what !
Working on a cooler for the bottom next.
Doug
I just hooked up a WeldCraft wp20 to my cooler and here's how I did it. Any comments? I looked at some other peoples ideas and went the same route.
- photo (9).JPG (89.2 KiB) Viewed 5697 times
- photo (8).JPG (91.99 KiB) Viewed 5697 times
Sweet Ive been looking ito getting a wp20 too But dodnt know if I want to go the route you went with that adapter block.DWRIGHT wrote:I just hooked up a WeldCraft wp20 to my cooler and here's how I did it. Any comments? I looked at some other peoples ideas and went the same route.
I still need a cooler but Your giving me ideas.
Good work on the set up.
jameswswanson
- jameswswanson
Nice cart!... and solution to the after market water cooled torch, but is it easy to switch the setup around?
Decision time.... First off I'm either getting a 250EX (then save my pennies forever for a plasma cutter) or a PP256, but before I put in my order I want to figure a few things out. I already have a water cooler, so I'm looking for a solution for hooking up an aftermarket Water cooled (ck 200) torch to a PP256, however the adapter block would make switching between Welding and Cutting a chore. Am I wrong? Also switching between Argon and Air... Has anyone come up with a clever solution, or will this drive me as nuts as I think it will.
Using a CK200 setup is simple. Here is how I did mine on my 250ex.jameswswanson wrote:Nice cart!... and solution to the after market water cooled torch, but is it easy to switch the setup around?
http://www.everlastgenerators.com/forum ... art-s.html
You will just need whatever fittings it takes to adapt to your cooler.
I have seen a post where someone used a three way fitting to switch between Argon to Air quickly on their 256, but don't remember off hand on what board it was posted on.
Millermatic 251
Spectrum 300 Plasma
Everlast PowerTig 250EX
Everlast PowerCool W300
Harris/Victor OA
Craftsman 13 Speed Drill Press
ProTools Air/Hydraulic Bender
48" Brake
Compressor, Notchers, Grinders, etc.
Spectrum 300 Plasma
Harris/Victor OA
48" Brake
jameswswanson
- jameswswanson
Thank you very much! This was exactly what I was looking for, the red adapter plug. Switching between Tig And Plasma will be a cinch with this setup.
