Josh MacD
    Wed Apr 26, 2017 10:57 am
    Phoenix AZ
I finally finished our new fire ring. It’s 14 ga steel, 17” tall, 38” OD and 23” ID. It’s elevated 2.5” off the pad for venthilation. There is some internal bracing and feet. The finish is premature rusting with vinegar, salt and hydrogen peroxide. I sealed it with Flood Penetrol. I welded with MIG welding with .025 wire. I did cheat a bit and pay to have the steel shop plasma cut the top ring and pre roll the rings. I am happy with how the whole thing turned out. Any feedback is appreciated.
Before glass was added
After glass was added
Hobbyist MIG welder with 75/25 gas on a Lincoln SP-140 in my garage/workshop/gym/storage space. Very new and still learning.
"Service is the rent you pay for room on this earth" - Shirley Chisholm
Prototypetom
    Wed Feb 28, 2018 5:29 am
Can you share you gas setup? Iv been looking at making one in a rectangle box
    Sun Nov 19, 2017 10:09 am
You got it done! It's beautiful!
Everlast 210 EXT
CJ737
Josh MacD
    Phoenix AZ
Prototypetom wrote:Can you share you gas setup? Iv been looking at making one in a rectangle box
I bought a kit off this site.
https://www.spotix.com/fire-pits/fire-p ... -kits.html
It was very simple. I needed a reduced coupler since my supply stub was 3/4”. And I didn’t use their expensive pan. I used the center drop from my top circle cut out. It was very easy. I do need to add a regulator at the meter since the output is a little high.
Jackomatic211
    Thu Jan 04, 2018 5:15 pm
Josh MacD wrote:I finally finished our new fire ring. It’s 14 ga steel, 17” tall, 38” OD and 23” ID. It’s elevated 2.5” off the pad for venthilation. There is some internal bracing and feet. The finish is premature rusting with vinegar, salt and hydrogen peroxide. I sealed it with Flood Penetrol. I welded with MIG welding with .025 wire. I did cheat a bit and pay to have the steel shop plasma cut the top ring and pre roll the rings. I am happy with how the whole thing turned out. Any feedback is appreciated.
looks really nice you did a good job
Josh MacD
    Phoenix AZ
For what it’s worth, i needed to go back and add in a regulator to take the pressure down to 125,000 BTUs
OzFlo
    Sat Sep 26, 2015 10:16 pm
    Sydney, Australia
That looks great Josh. I love the patina. Nice work!
TravisBeard
    Wed Feb 14, 2018 2:47 am
    Clinton illinois
It looks great. It might be a dumb question but where is you gas line running to? And what kind of rocks in the top?
Sent from my SM-G955U using Tapatalk
Josh MacD
    Phoenix AZ
TravisBeard wrote:It looks great. It might be a dumb question but where is you gas line running to? And what kind of rocks in the top?
We planned ahead and have the 3/4” natural gas line riser coming up between the inner and outer rings so that all plumbing is hidden, and protected, inside the steel ring.
The rock is fire glass. It isn’t cheap but we found some online on clearance.
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
great job.
i certainly will never let my wife see this post.......lol
