Bradk
    Sun Mar 12, 2017 11:09 am
    Santa Rosa, ca
A project completed from a Welding Tips and Tricks video (3 leg shop stool). I of course spent too much to build my version but that is because I had it powder coated and I had an upholstery pad and add a leather seat. Jody of course uses a bottle of stool softener as a spoof. Here is my version.
Brad
    Sun Nov 19, 2017 10:09 am
Looking good! I don't know if I measure up to rest my posterior on that. Should go into the parlor.
Everlast 210 EXT
CJ737
Bradk
    Santa Rosa, ca
This is the stool before it went into the beauty parlor
gwbruce
    Thu Aug 10, 2017 2:41 pm
I really like that. It gives me some ideas. I see a winter project in my future. :P
Bradk
    Santa Rosa, ca
gwbruce,
Yes it was a great little project which Jody has under his "projects" video section on his site. What I like about the stool is that it has a real good range of height adjustment. I have a Tab and Slot "Fab Block" that I weld at quite a bit and it works very well for that and I am sure other weld tables as well. I followed Jody's advice from the video and pulse welded the seams on the seat pan, tight fit up/no filler rod worked great! Enjoy your build!
Cheers,
Brad
gwbruce
Thanks Brad, I'll check out the project section.
ex framie
    Sun Aug 09, 2015 1:09 am
    Brisbane QLD Land of oz
Due to increasing mass due to ageing in most mortals some bracing may be of benefit leg to leg just above the feet.
This mass increase is most noticeable to motorcyclists when after riding season they put their leathers away in the cupboard for an extended period.
When next pulled out the leathers are demonstrably smaller.
Experts are divided on does the cupboard make things smaller or lack of riding make people bigger.
Cheers
Pete
Bradk
    Santa Rosa, ca
ex framie,
My 3 leg stool is stiff as a rock, I don't believe any extra bracing would be necessary even for the stoutest of men! No flex what so ever (thick wall tubing on legs)
Brad
