5" sch 80 6g / 2" ??? "thickwall" 6g tests
Posted: Fri Feb 26, 2010 10:10 pm
by justinT
I will be taking tests on these Monday at 7am.. 5" is tig root, hotpass, then 7018 filler and cap.. 2" is tig all the way out.. These coupons will be xrayed.. How should i run the 2"?? Any pointers or tips on these I would appreciate. The tests are for a job in Pascagoula, MS @ Chevron Refinery "LNG" project.. Anyone wanting information on this job they are still hiring combo welders.. You will need to goto Mobile, AL to apply @ adress and name below. Job is paying 26.50/hr if you pass both tests 25.00/hr if you only pass 1..
Performance Contractors
8093 Padgett Switch Road
Irvington, AL 36544
Mailing Address: P.O. Box 567
Theodore, AL 36590
Phone 251-957-0800
Fax 251-957-4887
Re: 5" sch 80 6g / 2" ??? "thickwall" 6g tests
Posted: Thu Dec 22, 2011 1:41 am
by Fluxedup
5 inch pipe with 2 inch thick walls. Root and hot pass with tig then fill and cap with 7018. Sounds like their making it easy for you...no key hole.. Surprised their not using 9018 though.
Posted: Fri Dec 23, 2011 5:07 pm
Um,
Two things.
You replied to a post that is nearly two years old.
He asked about TWO tests. 5" sch 80, and 2" heavywall (sch. 160)
Steve
