Page 1 of 2
Tack weld placement?
Posted: Thu Jun 09, 2016 10:33 am
by yamahablue
Is there any strategy to placement of tack welds? Do you put them at start and/or stop points and weld to them? Do you put them wherever and weld over them?
I'm going to be weldind a long, narrow, 3/16 plate to another and would like to tack it well. Lap joint.
Re: Tack weld placement?
Posted: Thu Jun 09, 2016 11:34 am
by MinnesotaDave
Really depends on the situation.
But for a narrow piece in a lap joint, make sure you tack both sides - it will want to pull the back side open as you weld.
For narrow, long welds - you may find warping becomes a major issue.
Experience will guide you in this.
By experience I mean - the #@$%# times it was too much and now has to be done over will guide you later.
Like installing a toilet - when you crack one you know that was 1/2 turn too much on the mounting bolts.
If a tack gets too big, I will thin it down with a grinder before I get to it - becomes invisible when I go over it that way.
Posted: Thu Jun 09, 2016 8:59 pm
by yamahablue
Thanks Dave.
Posted: Sat Jun 11, 2016 1:52 pm
by yamahablue
What would cause my wire to stick sometimes to the tack weld when finished, and other times it doesn't? Ive tried to notice what I'm doing different but haven't figured it out.
Another strange thing happened, I ran some beads in the small circle cutouts of this plate, the last bead I ran, the arc started sputtering like I was losing power. I pushed the tip in really close and barely was able to finish. It looks cold too.
Posted: Sat Jun 11, 2016 2:08 pm
by Bsmith
Take a picture. Does sound cold though
Posted: Sat Jun 11, 2016 2:11 pm
by Bsmith
Your wire speed could be too high as well.
Posted: Sat Jun 11, 2016 2:18 pm
by Bsmith
yamahablue wrote:Is there any strategy to placement of tack welds? Do you put them at start and/or stop points and weld to them? Do you put them wherever and weld over them?
How long is long and how wide is narrow?
What I'm picturing is gonna warp like mofo.
I'd probably tack it every foot or more. Weld one end 6" or so, move to other end weld same amount. Move to middle weld some. Jumping around like this will keep it from getting to hot and warpping.
Posted: Sat Jun 11, 2016 2:37 pm
If it's 3/16 thick then the center of the bead on a lap joint should be 3/16 of an inch thick. Measured like a fillet. Unless you need a solid bead for reasons like sealing up then weld it solid. I would tack about every 3-6 inches on 3/16. Have you concidered stitch welding it? I.e. Weld 3 inches and skip 3.
Posted: Sat Jun 11, 2016 3:13 pm
by yamahablue
Bsmith wrote:Your wire speed could be too high as well.
What's strange is that it just started doing it while welding, wasnt happening the other day or even earlier today . I actually quit now because it's falling on its face. I'm afraid that something is wrong with the machine or worse, my house wiring. It's a miller 211 that I have barely used, not even through the small roll that came with it.
As far as wire speed and voltage, I set it to the door chart for 3/16, then backed off the wire speed a little and ended up turning the voltage up some. It was looking ok to me, the extremely new novice. Now it's acting like it's dropping voltage mid weld., badly.
Posted: Sat Jun 11, 2016 3:35 pm
by yamahablue
Bsmith wrote:yamahablue wrote:Is there any strategy to placement of tack welds? Do you put them at start and/or stop points and weld to them? Do you put them wherever and weld over them?
Here's a picture for reference. I ended up tack it twice in every hole, top and bottom outside at every hole and a few on each end. Started welding the holes first until it started sputtering.
Posted: Sat Jun 11, 2016 3:41 pm
by yamahablue
Go easy on me, to be blunt, I don't know what I'm doing. This is the hole I first noticed the arc sputtering, losing power. I ran it top to bottom, right side then left. The right side seemed to be run fine, the left is when it started falling on its face.
Posted: Sat Jun 11, 2016 4:47 pm
by yamahablue
I just watched a trouble shooting video from miller, they said if the wire ever burns back to the contact tip to replace the tip. I had that happen but just freed up the wire from the tip. Do you think that could be the problem?
Unfortunately I can't remember if that happened before or after this issue.
Posted: Sat Jun 11, 2016 5:04 pm
by RamboBaby
You may have been pinching your wire when you turned the nozzle to the left side. Migs are sometimes as finicky as a cat. Sometimes they weld fine when there's no way that the lead shouldn't be pinching the wire and sometimes the wire gets pinched from the slightest little angle.
Posted: Sat Jun 11, 2016 9:32 pm
I think Rambo is on it. Bending the lead can sometimes bind the wire and cause it to drag. Make sure the liner in your gun matches the size of wire you use.
Posted: Sat Jun 11, 2016 10:39 pm
by RamboBaby
For someone who doesn't know what he's doing - that looks very good. No cold lap, fairly even travel speed through a radius. Nice.
by yamahablue
I didn't realize it was that touchy considering all the odd locations one might need to weld. I did move the machine after first experiencing this and welded another hole with similar results, both directions. The best I can describe it is like the voltage being turned down while welding. More spatter, having to push the nozzle all the way in just to keep it going.
Posted: Sat Jun 11, 2016 10:47 pm
by RamboBaby
You can have the lead line in a perfectly straight line and when you start to cock the torch to one side or the other the wire will begin to bind. Usually, in my experience you want to have the lead line in a bit of a rainbow arch to the opposite side of your body according to the direction that you are turning the nozzle so that the line and torch maintain a fluid arch. You constantly have to turn and move your machine and kick the lead line around to keep the feed wire from binding. It gets worse as you begin to work with the torch at higher elevations above the machine. Maybe they're not all like this but every one that I have ever used is.
Posted: Sat Jun 11, 2016 10:48 pm
by yamahablue
RamboBaby wrote:For someone who doesn't know what he's doing - that looks very good. No cold lap, fairly even travel speed through a radius. Nice.
Thanks, that's good to hear. If you saw the other circles you probably wouldnt be saying that. The first circles didn't look like that haha. At first I had tried running the top half first and then bottom but was having a hard time. Running it top down turned out a little better.
I need to learn how to position myself in a way that my hand doesn't block my view of the puddle. That was happening on parts of those circles.
Posted: Sat Jun 11, 2016 10:51 pm
by RamboBaby
Try switching hands.
Posted: Sun Jun 12, 2016 8:55 pm
by yamahablue
I don't have any more circles on this side to do, the whole outside edge to do though. I'm going to give it another try tonight, I put a new contact tip on and I'll try maneuvering the lead like you described.
Posted: Sun Jun 12, 2016 9:43 pm
by Bsmith
But why are you welding it out? It doesnt look like it needs it.
Posted: Mon Jun 13, 2016 3:46 pm
by yamahablue
Bsmith wrote:But why are you welding it out? It doesnt look like it needs it.
The manufacturer intends it to be, every photo I can find of others, are fully welded.
Unfortunately the straight runs are giving me even more difficulty than the circles did. The bottom side especially, with the nozzle pointing up. I'm producing some horrible looking welds.
Posted: Mon Jun 13, 2016 4:43 pm
by RamboBaby
Make sure rhat you have adequate tension on your drive rollers. This video will show you how to tension them:
Watch "Mig Welding Basics" on YouTubeMig Welding Basics:
http://youtu.be/5KrwmK7df-s
Posted: Mon Jun 13, 2016 6:56 pm
by Bsmith
yamahablue wrote:Bsmith wrote:But why are you welding it out? It doesnt look like it needs it.
Horrible looking how? Do you have a picture?
Posted: Mon Jun 13, 2016 10:18 pm
Drive rollers do wear out. If the flats on the wheels bottom out on each other before they grab the wire it can cause feed issues. But pictures of the finished weld will help you get the answers you want.
