Mike926443
    Wed Apr 06, 2016 2:53 pm
Hey everybody, this is my first post and I'm glad to be here. I noticed something in my mig welds the other day. At the end of them I noticed a little pinhole reohnt in the center of the crater. It only happened on a few of my welds. I was weldinging 1/8" wall thickness rect. tubing to 3/16" plate and I was well over the recommended settings. Probably by about 1.3 volts and 50 wfs. I didn't clean the millscale off as well. I thought that that may have been the case or that I was too hot. I'm not for sure though so if somebody would explain I would greatly appreciate it. Thank you again
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
You need to "button off" your end crater to avoid cracking.
When you finish your weld keep your gun in position for a second or so to allow some solidification then fill the crater with a quick blat. This is good practice with all mig work.
Mike926443
Ok cool, thank you for the response. What is the cause of this though?
Coldman
    Oz
Shrinkage. Where you finish the puddle draws downwards as it cools and shrinks forming a crater and in your case a pin hole.
Coldman is 100% right on this... I meant to reply on buttoning off, but my duties interfered.
On a heavy section, weld of 5/16 or greater, I'll button off twice. The first, I'll stop only maybe half a second and add filler, then a second later hit it again. You want NO crater at the finish, as that's where cracks start. Your pinhole is the point of origin for a cracked weld.
