rockchopper86
    Thu Dec 23, 2010 4:48 pm
hi new here my names alan been welding for quite a while just got a hobart ironman 230 as my first home mig and im very happy with it except id like to upgrade to that miller ground clamp with the shunt that jody always recomends. my problem is other then the pic that he put up i cant find any info about it so im hoping somebody could help me find a place to order one online?
rick_barter
    Thu Dec 02, 2010 10:48 pm
Have you seen this article? http://www.weldingtipsandtricks.com/mig ... ip-19.html
I have seen these clamps at welder's supply places and even at Tractor Supply.
Here are some copper clamps online:
http://www.weldfabulous.com/Welding-Cab ... 21299.html
http://www.weldfabulous.com/Welding-Cab ... 00546.html
Hope this helps.
rvb
Steve from Ohio
    Fri Nov 26, 2010 12:53 am
Harbor Freight has the very same ground clamp for 8 bucks. It is a 400 amp clamp made of brass. Use the wire tip that Jody shows and you will be good to go. No more bird crap welds for sure!
Steve from Ohio
The Harbor Freight 400 amp brass ground clamp has now gone from 8 bucks to $17. And they say there is no INFLATION.
ogorir
    Tue Feb 23, 2010 9:04 pm
    Waco, TX
you got that clamp on sale for 8 bucks. it's 'on sale' every other week :) it's a good clamp, though. the spring is REALLY stiff, though. like... if you don't grip it right, you're not opening it far enough to put it on 1" sq tubing stiff.
kermdawg
    Tue May 25, 2010 8:16 pm
Wow, either the dollar went way down (not the case) or the chinese finally let their currency float to where it should be(the case and we're all screwed)
delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
I switched all my clamps from those crappy pressed steel ones to Radnor all copper clamps. It made a huge difference. The 300 amp ones were about $32 each at Airgas. Well worth it.
