What is it?
Posted: Thu Feb 25, 2016 2:06 pm
by bigworm40
Can someone please tell me what the white substance along the edges of the weld is.
Re: What is it?
Posted: Thu Feb 25, 2016 4:08 pm
by jeffBrian
8-)
Re: What is it?
Posted: Thu Feb 25, 2016 7:02 pm
by bigworm40
A570 GR 50
75/25
Lincoln 71A85 Ultracore FCAW G
Re: What is it?
Posted: Thu Feb 25, 2016 7:11 pm
by jeffBrian
Probably just contaminates from the steel being dirty. can you explain what where or when this is happening. a lot of times people over think the problem and it's something really simple to fix. this may be the case here.
Re: What is it?
Posted: Thu Feb 25, 2016 7:14 pm
by jeffBrian
are you running correct gas for the wire?
Re: What is it?
Posted: Thu Feb 25, 2016 7:26 pm
by bigworm40
Yes 75/25
Re: What is it?
Posted: Thu Feb 25, 2016 7:41 pm
by jeffBrian
everything I've seen so far says high argon concentrations work best. the cfh rate is 40 to 50 also which is a higher flow. perhaps trying a higher concentrate of argon gas and check flowrate. other than that I'm still looking a bit. it's interesting because I've worked with guys who worked shipyards in Seward and I bet this wire is used. I wish someone else would stab at this with me.
Re: What is it?
Posted: Thu Feb 25, 2016 7:54 pm
by jeffBrian
could you try 85/15? here is just an explanation of the argon mixtures
Re: What is it?
Posted: Thu Feb 25, 2016 7:58 pm
Where did the metal come from? Is it steel or some grade of SS ? Is it galvanized or from a corrosive enviroment? I've seen some weird stuff bubble up through or from contaminated metals.
Re: What is it?
Posted: Thu Feb 25, 2016 8:20 pm
by jeffBrian
bigworm40 wrote: A570 GR 50
75/25
here's his response from earlier
Re: What is it?
Posted: Thu Feb 25, 2016 10:05 pm
I was wondering if it was used and maybe permiated with some kind of chemical.
Re: What is it?
Posted: Fri Feb 26, 2016 12:44 am
by jeffBrian
I would get two maybe 3 other pieces of test material and run a bead on each. that should give you a better idea what's going on.
I don't think you specified if it was giving you this with just the one material you posted a pic of or all pieces. if you're wanting to know what's bubbling out of the metal just out of curiosity then I totally missed that. ... and now I feel dumb haha
