Settings for Different Thickness
Posted: Wed Feb 03, 2016 9:32 pm
First off, I am a total noob when it comes to welding. I bought a Hobart 210mvp and have it hooked to 75/25 gas
This weekend I'm going to have to remove the skid plate on my jeep. The skid is held on by bolts threaded into nutsert installed in the frame. since it is old a rusty, I know some of the nutserts are going to spin loose. I plan on installing the new nutserts in the frame as recommended but then wanted to tack them once or twice for extra strength.
The welder has the chart for the settings based on the thickness of the metal. What thickness should I use since the frame is a good bit thicker than the "washer" part of the nutsert
